... what's the difference between an SS ute? And an SS sedan.. and an XR6 turbo and an XR8 and a magna and the stint with WRX's?
Nothing I say, that's their new line of defence, get personalised plates to try and fit in further. They'll do anything to try and catch a few more unsuspecting fools.
$2000 on plates is easily made up in a three month confiscation in fees and fines for ONE of the drivers caught.
I should email the guy that I used to work with and he used to hassle me about hooning :thumbsup: I'm now hassling him about new undercover cars, seems fair to me!
  • Replies 60
I think you'd have a pretty good defence in court if you didn't pull over for a black SS ute with personalised plates that tried to pull you over. Any yobo in his SS Ute could get a flashing blue/red light stick it in his window and pretend to be a cop.
"I saw a late model SS Ute driving erratically, then suddenly started to try and pull me over, i feared for my safety, thats why i didn't pull over"
Thats good in theory, but in practise, if you do run and happen to be black, the probability of being shot is pretty high :D
Spotted another Ford black ute with rear canopy
Reg number RYM22 had a theme on the plates as well
Was doing hand held laser radar on Redland bay road Capalaba on Wednesday arvo 12.1.05
Two men in full uniform booking people
Did not have lights on top or police stickers down the side.
Very stealth!.
Ok yes its true....
I have sourced the info.... True....!
There are more cars than you know about tho..... (other than the SS).....
There are more like 17 cars driving our roads everyday....
Everything from a magna to a corolla
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
