At a guess i'd say he's not running stock turbos...
The Rb26 Internals usually can cope with the 320rwkw you want... as Leewah said the stock turbos/fuel system is what struggles
If you've upgraded injectors/turbos and usually ECU, a good tuner should be able to get you well over 300rwkw - Go see Racepace.
i picked up my car from workshop in March, but i hardly push it as my girl will konck on my head if i do so...anyway, i have following mod on my car:
PowerFC,
HKS GT-SS,
HKS 600cc Injectors,
HKS Type-R Intercooler,
Nismo Fuel Pump,
Sard Fuel Regulator,
Tomei Cam Gears,
and other pieces...
all i'm worried about is internal, dont know if it will hold that sort of boost pressure and power or not.
i picked up my car from workshop in March, but i hardly push it as my girl will konck on my head if i do so....anyway, i have following mod on my car:
PowerFC,
HKS GT-SS,
Nismo Fuel Pump,
Tomei Cam Gears,
and other pieces...
all i worried is internal, dont know if it will hold that sort of boost pressure
ok well the boost shouldn't be a problem but i think your better off looking in other area if you want a bit more hp, as offen exact boost doesnt alway mean much exact power. I can only talk from my experiences but my gtr r33 is running around 525hp on stock internals and is quiet happy .Its been around 500rwhp for quiet awhile now and with no problems i do intend on upgrading internals in time as i'm currently buy the components for it.
but to show boost to rwhp relationship on mine at current tune
13psi ~440rwhp
15psi =484rwhp
18psi =512rwhp
20psi =525rwhp
as you can see the last couple of psi arnt gaining much hp and i normal drive it at about 0.9 bar (~440rwhp) on the avcr and just turn up occationly for a bit of a blast etc
the biggest gain in the development of my ride were the install and tune of power fc and then later the install of tomei poncams 260 9.15mm with adjustable wheels
but all the hp from the cams came when i tuned them in ie over a 100 hp increase just from tuning the cams, so i would suggest a nice set of cams (make sure you take the time and tune them) would be a good investment AS LONG you have already upgraded the exhaust turbos back and the inlet system ,as these should be your first mod (i didnt see them in your list, but you may not have mention them )
pete
ps i hope this helps
:P
i have HKS dump pipes, front pipes and 80mm cat back
a r32 GTR from one of the jap magzine got 671hp flywheel at 1.5bar with stock internals
it has:
HKS stage1 cams
HKS 2530s
HKS 1.2mm headgasket + other usual mods to go with the turbo
however, i'm sure that jap is using higher octant fuel and much cooler than aus, which does make differences
it has:
HKS stage1 cams
HKS 2530s
yeah sounds about right with a 20% loss(not sure on exact loss) through drive train that would be about 536rwhp and i have seen a 550rwhp gtr with hks 2530's at 25psi (1.7bar)on std internals BUT i think that may have been on better ron fuel ,but do not exspect this power for to long from a std engine as i only turn up the wick occationly .
the other thing is the garret 320hp ball bearing turbos and hks 2530 (320hp) seem to be a very close match (if anything in my opinion the garretts are best at lower boost around 1.3bar but the hks come into there own at the higher boost setting 1.5 to 1.7bar) but your hks gtss turbos are only around the 280hp per unit mark so may not flow the same sort of rwhp. But you should have very good responce and spool up.
pete
ps i think cams are the go for your set next and i reccomend tomei poncams 260 deg 9.15mm lift these are a direct bolt in unit and require no head machining (there about as big as you can go with out machining) they are simply an awesome cam :wassup:
...ps i think cams are the go for your set next and i reccomend tomei poncams 260 deg 9.15mm lift these are a direct bolt in unit and require no head machining (there about as big as you can go with out machining) they are simply an awesome cam :wassup:
i'm thinking of getting those cams too (still std engine). what other mods would you put with the cams or is that all you need? different valvesprings, etc?
i have these cams on my bedroom floor :(
uLa32: they're supposed to be bolt-in; as long as you don't raise the rev limit too much, the stock valve springs should be ok? I'm not changing mine :D
Would go with adjustable cam gears though
how do u like ur gtss turbos?
im running 1.1bar on my stockies and id prefer to change them before they blow
They goes hard on the 1st, 2nd, 3rd....but from end of 3rd to 5th....they are not as good~~~!!! therefore, i would say GT2530s would be the best choice for a stock RB26DETT
Danny, there are two types of Poncams - Type A and Type B.
Type A - IN 260 EX 252, 9.15mm lift
Type B - IN 260 EX 260, 9.15mm lift
http://www.tomei-p.co.jp/_2003web-catalogu...r_engindex.html
:rofl:
I have type B
How come Nengun has 2 Type-A
1. IN 260 EX 252, 9.15mm lift
2. IN 260 EX 256, 9.15mm lift
and Type-B the one you bought
Type A
In order to get stable idle and raise low-mid RPM torque, we set the duration of EX camshaft shorter.
Best suit used with stock turbine or N1 turbine.
Type B
By giving longer duration timing than type a, it eables to raise both response and peak power at the same time, even with mid-large sized turbine.
I am a complete lover of Tomei equipment, after fitting Tomei PONCAM's to my already modified SR20, I got a completely new car, so muhc fun to drive, so I am more keen on going for an even higher lift cam this time, I want to keep the revs low adn I love mid range and torque.
So I am thinking of going to the Tomei PROCAM 260deg 10.85mm lift along with Springs and lifters, I think that these cams should really be a great addition to mid range addiction.
Anyone running these cams?? Just hoping the 2530's won;t run out of puff on these cams, my last turbo on my SR20 did, dropped 1psi at redline.. :rofl:
I haven't done Desktop Dyno simulations yet, but I will very soon. The ones for the SR20 was pretty close to what I measure with my GTech Competition Pro - no dyno for 1600kms..
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
