have to catch me first, my car may not be as quick as yours but I am sure i know a few tricks, like getting out and running across rough ground. lol.
I'm told my Skyline's attracted to the ruff..He he he
I'll need to buy me one of those Paris to Dakar type vehicles so I can get around that circle and up the qtr in relative safety.
https://www.sau.com.au/forums/topic/61240-jerra-impromptu/#findComment-1157582
yeah Sean, no good running over rough ground esp median strips, Richards been known to be able to throw the GTR over them with relative ease, haha.
i wont be there, im going to a friends 18th at the Hellenic, rumour is that she has plenty of hot friends that hopefully by the end of the night should be relatively "easy" muahahaha!!! :aroused:
oh and it's an open bar :ddd: , (its times like this i wish i drank) maybe Richard could come along as my um, "older" friend and try his luck? remember once they're 18 its legal :whip:
https://www.sau.com.au/forums/topic/61240-jerra-impromptu/#findComment-1157632
Ah ! Laws were made for breaking and so are young girls...
Jokes OK
https://www.sau.com.au/forums/topic/61240-jerra-impromptu/#findComment-1157729
it was a blast tonight except the incedent i had in Adam n Eve at fyshick
I thought you told me it was your Clutch not your Crutch. Next time pay up and dont do the runner.
Last time I worry bout your problems.
https://www.sau.com.au/forums/topic/61240-jerra-impromptu/#findComment-1158608
Well i needed to vent some......... pissed offness, vented all good now, except now i have no clutch and 4th is not happy i dont think, well after trying in vain to slam it into gear at 80clicks it kind of just really badly grinded. So does any one know where i can get a new clutch not crutch
edit..
Stop twisting my messages. It makes me look worse than normal
https://www.sau.com.au/forums/topic/61240-jerra-impromptu/#findComment-1159748
clutch shop ???
Nah I got mine from UAS on special, 6 puk brass button (for gtr), 480 exchange, 640 no exchange and its 880 normally, keep your eye on them, perhaps give them a call.
+ install of course.
I had a good back yardy do mine in the gtr for 160 install. but he's not available anymore.
https://www.sau.com.au/forums/topic/61240-jerra-impromptu/#findComment-1159874
Snooze - What time did u get up?
If you wait long enough the link at the top will flash up UAS. Site has a location map (Sydney).
here ya go http://www.nismo.com.au/
well i have all the tools do the job myslef,, so hopefully I can do the job myslef. save some bickys, where is UAS. I might wait till boys from trojan are back.
https://www.sau.com.au/forums/topic/61240-jerra-impromptu/#findComment-1160066
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
