1992 Burgundy Red R32 GTS-T Mspec
86000klms
5speed
18" Gold AVS model 7 Mags
3.5" zorst from the turbo back
Hi-flowed R34 turbo
NPC 2600lb Brass button clutch
NPC lightened flywheel
Bosch 040 fuel pump (550hp)
Frount mount intercooler
turbosmart type 3 supersonic BOV
cusco oil catch can
pod filter
apexi safc (Tuned by chip torque to 18psi)
Turbo smart bleed valve
Blitz full automatic turbo timer (FATT)
autometer boostgauge
Strut brace
(not sure about the suspension but its not standard)
Alpine head unit, pioneer 6x9's, JVC 6" 3 ways
Page gaurd 1000 alarm
187RWKW at chip torque
$18500 ono
Boondall, Brisbane
Anyone interested contact me on
0431 368 411
https://www.sau.com.au/forums/topic/61881-1992-r32-gts-t-m-spec/
Interested in a trade for a 180SX with 208kwATW, very nice looking car with alot of mods.
Let me know, I'm in Brissy too.
Sorry champ trading it in for a bike, any other info on the car is only a PM away.
Thanks
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
