With a Electronic Boost control can you alter boost pressure at different rpms. Im getting 17psi at 4500rpm and then it drops off too 12psi and peak revs. This is using a HKS actuator and no bleed valve so its not the actuator spring. So i thought with a EBC could i dial in more boost pressure at say 6000rpm.
Can i do this?
  • Replies 46
Some EBC's are not intelligent.
Some operate in a closed loop mode that monitors boost and adjusts the duty cycle to suit. The cheaper EBC's tend to have a fixed duty cycle which is why you get boost dropping at higher rpm's.
I used to own a Blitz SBC-ID EBC that had a manual function and auto function.
The manual function was like the regular ebc where you set it to a duty cycle.. Say 43. then you set the gain which controls how fast boost reaches that duty cycle peak if that makes sense. It would make 15psi then tapper off to 12.5psi by 7000rpm.
Then there was the auto function that would require you to dial in the boost you want (say 15psi) it would then slowly learn the boost curve and adjust the duty cycle to suit. This would require multiple 7000rpm runs.
Once learnt it knows that it has to reduce the duty cycle in order to hold that 15psi a certian RPM. It would then hold 15psi to redline.
Wait until you get the PowerFC & get the boost controller to suit that. :mad:
The PowerFC boost controller is essentially the same as the AVCR which is a very good boost controller. Some do not like the AVCR due to its complexity and thoughts that a bigger solanoid is better. Which is untrue. :mad:
EDIT: Stock turbo or not.. It has nothing to do with it. A good EBC will hold boost. i.e the rb20t turbo was able to push 16psi at 7000rpm on the rb20det when with a crappy bleeder it would tapper off to 12.5psi. You need an intelligent EBC. AVCR, Blitz SBC-id or the Greedy E0-1 (Expensive) I think it is.
How good of a boost controller do you consider something like a GReddy Profec B-Spec II, or even a Spec-S?
 Wait until you get the PowerFC & get the boost controller to suit that. :cheers:
The PowerFC boost controller is essentially the same as the AVCR which is a very good boost controller. Some do not like the AVCR due to its complexity and thoughts that a bigger solanoid is better. Which is untrue. ;)
AVCR lets you do everything. :cheers:
fuzzy logic, rpm & gear based boost. everything.
GReddy Profec B-Spec II, or even a Spec-S...
I don't know I would have to read up if it has a boost curve learning mode.
If you simply dial in a number say 42 or 45 that has no correlation to the boost figure
its self then it is based on a percentage of maximum boost hence duty cycle.
That is when you will run in to trouble as you cannot get the boost controller to increase or reduce the duty cycle when needed to hold a certian boost.
you will never be able to sustain 17psi throughout the entire on-boost rev range with a 2530 on an rb25. 2 different tuners in here in SA explained from their experience that apparently there is too much exhaust flow from the rb25 at the top end, where the compressor is "spun out of its efficiency" and starts to "chop" the intake air rather than compress it. we were also running 17psi and it always dropped off to 13psi at the top end. in this case, its the turbo, not the EBC that is responsible for the pressure drop. Before we we're told this we had tried 2 different wastegate actuators and 2 reputatable EBC's, all to no avail.
just be happy with the mid-range :D
a HKS EVC 3 or 4 will give the best control out of all of em...
but doesnt offer the fancy stuff like Gears vs Boost... guess thats why they are $150 cheaper. No flashy shit. Just controls boost you ask for
But i was thinking i could run 17psi in the midrange and when it starts to drop, somehow try and squeeze more boost into it without trying to boost to more than 17 in the middle.
Mate you can up the boost all you want but with a 2530 all ya gunna do is make hot air. And all that will do is bring you that bit closer to detonation.
and you know this because why?
do you know where a 2530's Efficiency range is?
its certainly not at low boost - 10-15psi. HKS turbos are designed to perform better at higher boost... not just "make hot air"
Greddy Profec Spec S is like the old Profec B just with an upgraded solenoid.
Profec B Spec II is a bit of a pain to set up.
Check the link bellow, its bit old but good info.
http://www.sportcompactcarweb.com/tech/020...boostcontrol05/
no offense, but i dont think youve had much, if any, experience with 2530's on rb25's, because if you had, youd know that you cant "up the boost all you want".
not trying to shit stir here, but im coming from direct experience in collaboration with 2 reputable SA tuners.
no offense, but i dont think you've had much, if any, experience with 2530's on rb25's, because if you had, youd know that you cant "up the boost all you want". if you have had experience with this setup, i really want to know how you did it, because it was a real pain in the arse :)
i think if it was capable of sustaining 17psi at the top end, after all the tuning and trying different things, we would have been able to make it happen.
now on a rb20, its a different story, smaller engine, less exhaust gasses. my good friend with a 2530 on his r32, making 240rwkw, can sustain up to and over 17psi across the top end.
not trying to shit stir here, but im coming from direct experience in collaboration with 2 SA tuners.
it seems to be all due to excessive exhaust gasses. i've always thought that if you enlarged the wastegate, you would be able to bypass more exhaust, slowing down the exhaust turbine and hence bring the compressor back into its efficiency. does that sound right?
i know its not all about the exhaust turbine and housing that matters, but, we have a 2835proS on the 25 now and both the exhaust turbine and its housing is considerably larger than the 2530, and it sustains 17psi rock steady across the top end, and wants to keep going. its so easy to hit the limiter because there is no letting up in the power delivery. after a rebuild it would be interesting to see if we could find the point, if there is one, where boost drops off at the top end with this turbo. but i dont think id like to push it that hard :)
The wastegate on a HKS 2530 is bigger than the stock R33 turbo, i guess its still not big enough.
Does the 2535 have a bigger exhaust wheel than the 2530?
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
