i know this is mainly a skyline forum so ill be brief. im in the US so we didnt ever get those lovely silvia's or skyline's and i was just wondering if you guys know the specs on the s13 redtop and blacktop stock? when i look on the net all i get is different guesses and some motor dyno's. since they were sold over there, could you guys let me know what they had off the lot? asking redtop and blacktop because i heard blacktop came with a little more but ive also seen that they had the same horsepower. thanks for any help.
https://www.sau.com.au/forums/topic/62308-s13-redtop-and-blacktop-specs/
Try this website mate,
http://www.nissansilvia.com/
lol someone already suggested that.
i wasnt planning on going vvt. dont feel like messing with s14. there are 2 s13 det's tho. redtop and blacktop. just making sure no one is confusing blacktop s13 with the vvt s14. getting the blacktop is just as easy as getting the redtop for me and the cost is just a tad more. the blacktop is newer (doesn't mean ill get a better motor i know) but the main question was just whether or not they added a bit of power when they changed over to s13 blacktop from redtop or if they just had a different valve cover.
the s13 blacktop and redtop are the exactly the same engine . one is red . one is black
as you stated the s13 blacktop comes in around late 93 so they are newer engines but be weary as often they are red tops painted black to ask for slightly more money
