There sure is - well sortof!
The main differences can be seen on the outside. The Series 2 has a different wing, front bar, bonnet and headlights straight out of the factory. From memory there are minor differences in the engine bay, the turbo in the series 2 are different internally from 1 as they are said to spool up quicker than the series 1.
hey, i dont think it is aftermarket, i have seen lots of r33s (series one mostly but have also seen series twos with them on) with that exact grille on them, so maybe it was a factory option...
Definitely a factory option on S1 models, have seen both grilles in the FAST parts list.
S2 grilles are kinda similar, but a bit narrower. And front bar aftermarket kits not-withstanding, I've only ever seen one type of S2 grille?
For other S1 vs S2 differences do a search, zillions of threads on that topic.
i still dont get it then why mine has the fornt grate and urs doesnt.
If their both s1 and made in 93...
'Tick the box' option in Japan - along with things like the different front bar, side skirts etc.
I thought S1.5 refers to a S1 with any S2 bits on it - mine has a S1 exterior and interior, but has the S2 engine. Looks like Nissan did a heap of mixing and matching during '95 so S1.5's could be any combination!
Gatty - you could order the mesh type grille from Nissan - I've seen the part number is listed in the FAST system, so they should be able to look it up for you. Or get an aftermarket one (probably cheaper!), I got one from East Bear in Japan:
http://www.east-bear.co.jp/aeroparts/skyli...33/f-grill.html
Run it thru Babelfish for a translation:
http://babelfish.altavista.com/
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
