My GTR has got a rattle the ass end and after checking everything pretty sure it's the rear subframe bushes (the ones closest to the front ) that are making the noise specially as one is leaking sticky fluid .
Now my question is how hard are they to replace,who should I be seeing and what are my best options ?.
You can do it yourself, but there is a bit involved - few things to remove to make it easier. the 'pineapples' eliminate much of the squish, but will transfer more shock.
See if you can get a tyre shop to put it on a 4 post hoist - might make tracking the problem easier.
hi, I just did this job on my R32 GTS4, and it is a large job, not that difficult but definitely time consuming.
I bought another subframe removed the bushes and then put new bushes into it and then replaced the subframe on the car. I have just removed the bushes from the subframe and am planning on selling it.
If you do the hard part by yourself and then have subframe fitted by mechanics(who know what they are doing) it is about $400-$500, to remove subframe from car, transfer the diff and suspension links over to new rebushed subframe, refit subframe and bleed the 4wd system. Up here in Brisbane they will charge you about $1000 to do the complete job + bushes. UAS has them for about $160 set of 4 noltec urethane bushes.
You can do it by yourself but you need to be patient and careful. The job will take 10-12 hours. 4 hours to get bushes out and fit new ones. 1-2 hours to remove subframe, 2-3 hours to remove & fit suspension - it is much easier to fit bushes if subframe has nothing attached to it. 2-3 hours to refit subframe to car and hook everything up and bleed attessa. + a wheel alignment.
It is the better solution than pineapples as they tie the subframe more securely to the car, apparently the urethane bushes will also negate some of the 4ws that the hicas does(it relies on the compliance of the bushes to help it steer the rear wheels) but it is much more expensive as earlier mentioned, I've heard that down in sydney some are charging about $1500 to do the job which is a bit excessive!
My car feels much tighter now and I will be taking it to QLD raceway for a trackday on tuesday so I am expecting the car to handle a bit better.
Stephen
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
