OK
those of you that have seen my recent posts will now that I have just rebuild the motor in my R32 GTR (should get the beast back this Friday). I have strengthened the bottom end and done a minor port and Polish (with a few other bits too) – but the major upgrade replaces the std turbos with a pair of N1s off an R34 V-SpecII
These are relatively small (street) turbos I know – but how much boost can I safely run – and where can I find some info (specs) on these turbos.
I've done a few searches – but didn't find too much
TIA
https://www.sau.com.au/forums/topic/62632-n1-turbos-how-much-boost/
  • Replies 43
My upgrade plan is as follows (in order)
Stage 1: full rebuild with forgies + the N1s – done
Stage 2: PFC + HC and dyno tune (real soon now)
Stage 3: 044 fuel pump + 700cc injectors + Splitfire coils
Stage 4: 600x300x100 FMIC + hard piping
(did I miss anything?)
I'd like to keep the boost under 20psi – just to be on the SAFE side
I'll probably do AFMs somewhere along the way too – see my post about RB25 AFMs on a GTR
The bigger FMIC will keep the temp down - yes
any guesses on a rwkw for this sort of setup
1.2bar is the most I would go, N1's perform well at that boost , At the end of the day dyno figures don't meen much it's all about power delivery and how early on your making boost which equals good times at the track .
An example of that theory would be wrxhoons's (from these forums ) r33 GTR he's running a Power FC tuned by Ben at Bel performance , n1 turbo's at 1.2bar , catback and front pipes , everything else stock even the air box and he has gone 11.7@119mph out at WSID with 60ft times that aren't all that great . The car would also perform equally well on the roundy roundy stuff as it has a usuable power delivery .
i know wrxhoons car as well and 1.2 bar would be the best or else very close to best (stock injectors were close to the limit)
also the best time was 11.7@121mph with stock wheels.
i am under the impression that there are a number of n1 housings which means some will be laggier than others.
all n1s have steel wheels, although only r34 have ball bearings.
thanks guys - this is good info
my N1s are defiantly from an R34 - and are the Steel Wheeled BB type
AFAIK the stats for them are as follows
.64 A/R ex (I think)
76 Trim
compressor is .60
I'm not expecting much lagggggg from these
supposed to be rated at 320hp each
so does that mean 2x320 = 640hp for me :)
640hp = ~480kw yes ?
corrections welcome :D
so was wxrhoons N1 SS/BB (R34s) or not ?
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
