Here is a list what i have done in the last three days
Keep in mind I did all this without any help.
Auto box is sitting next to the car...
motor sitting in engine bay but not bolted in....
crank is different to the engine i pulled out...fark...need a manual
get clutch
fit clutch
get pedal box and clutch master and slave cyl from r31 and 200b and modify to suit application
manual in...
all anciliaries bolted to motor
gearbox is 5inches shorter than the auto
fark....manual out.....run around like an idiot looking for a long 5speed(impossible to get one atm)
find out that crank is NOT different...
there is an adapter on the end of it....pulls off with two tyre levers
put auto back in....
realize that i cut all the lines that the auto uses when i took it out as i wasn't using it
run around like an idiot again to find the cooler lines...
find some at murrarie.
remove clutch master slave and pedal and go get auto lines.
go cruising Sat night in Nismogirls car.....
get a defect in my bog stock silvia
fit auto lines to gearbox....remember that the motor doesnt have an oil pickup in it yet...
undo engine mounts
lift engine and remove sump....
go 1/2 way to toowoomba to get oil pickup
fit oil pickup
fit sump...lower engine....do up engine mounts...
fill with oil...fill auto with tranny fluid
fit tailshaft
try to start car,,,....nothing
find that wiring is all wrong on the auto...
fix wiring...try to start car....
car starts.!!!....exaust isnt done up.....FARK its loud!
turn car off.
fit exhaust
start car.....runs on 5 cyls only.....
begin diagnosis
find that no2 cyl is not firing.....
plenty of spark.....
check exhaust....no popping....not a valve
must be fuel suply to Injector....nope...plenty of pressure..
guess that injector must be the problem...remove injector(cvnt of a job)
replace injector
start car...WOOOOOO firing on all six!
fit radiator and hoses
fit fan
fill with coolant
let the car idle for 20 mins
not getting hot, go for a small drive....temp on 1/3....sweet
sit down and relax
What motor are we talking?  And which car?  The coupe or the sedan?
I cannibalized my Hilux project and pulled the L24e from it and fitted it to the sedan.
The hilux is now a no go. It will be sold for next to nothing, or dumped. I need it gone, so I can begin on the coupe.
Nope. Springwood. That's the issue.
Jason jumped in our car at springwood, cruised around all night, got back to springwood, and drove his stock standard ca NA silvia the 100m to Springwood maccas and the cops pounced on him even before he got out of the car. His numberplate isn't visible to australian standards apparently.
They said that my plates were ok along with the commodore beside us. They were targetting each and every silvia that came into the carpark sat night. As soon as one came in, they pounced.
Pretty pathetic.
actually.. friday night too i saw them around there too.. they were doing over a commodore.. so least it's not *all* the imports.
I think they are on a big revenue raise.. why exactly I don't know.. It's not as if a lot of the fatal accidents involving imports have been in QLD at all.
Its ok Jason, I whinged for you
From http://www.boostcruising.com/journal/entry.../7/no/3617.html
^~^~^~^~^ - This here is why cops suck. The guy left his girlfriends dead stock automatic CA18 powered non-turbo silvia at Springwood and hitched a ride with us down the coast. Once he returned he drove the massive 100m up the road to Springwood Maccas to have a yap before heading home.... Unfortunately a pair of chumps wearing badges decided his car was defectable for his numberplate. Never mind the fact its dead stock with the numberplate fitted in the factory position, these guys decided a defect was definately neccesary. The reason given was that the plate cannot be read from a 45 degree angle at a distance of 20m. Im assuming this is because that is the angle required for a speed camera or red light camera to identify your numberplate and send you a nice revenue raising bill in the mail. Plenty of local cars in the carpark also suffered from this identical problem, specifically an Astra sitting two carpark spaces... In the meantime, countless rust buckets oil-smoked their way through the carpark. So yeah, just a warning to you silvia owners - check your numberplate position. Dunno how you are supposed to rectify this situation (but then again neither did the pair of chumps), so maybe a call to department of transport to clarify the laws on this? As a side note, if the owner of a red celica with a GT-FOUR bonnet (prehaps the whole car is a GT-FOUR but I didnt take enough notice) notices any dents and scratches on the passanger side of the bonnet, its because one of the chumps dropped his copper issue bum-bag utility belt thing full of heavy shit on the bonnet. A pity the night was ruined by the most roadworthy and legal car of all of us getting an unfair fine, but thems the breaks. Hopefully he can succesfully contest it as it would be pretty crap if a car can be legally complied with a defect like that. Anyway, feel free to whinge... I sure did.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
