Guest 90degrees
hey dude i know a place that gets them made on the goldcoast.
fabtech autostyling i shopped around in brissy and g.c for one and these guys had the best they get them in alluminium or stainless i got the stainless looks pretty trick and does the job give them a call and see how you go.(no. listed below)
fabtech autostyling
(07)55281990
https://www.sau.com.au/forums/topic/6307-oil-breathercatcher/#findComment-94778
correct me if i am wrong but i beleive they are an out let for the oil vapours for when the engine is working hard, the breather is there for the vapours to go into but if it is not the vapours recirculate and can cause pinging as is the case with my car.
thanks heaps for that guys...i will give the guys at GC a call...have you got any pics of yours ?? and did they fit it or did you do it yourself ?
https://www.sau.com.au/forums/topic/6307-oil-breathercatcher/#findComment-95007
Guest 90degrees
na dude i havent played with it yet in fact i havent even serviced my car since (shame) im sure they can fit it for you there they also have the filters for them to (i looked everywhere for one before they got them) i fitted it myself.it does idle better with it and runs smoother...
https://www.sau.com.au/forums/topic/6307-oil-breathercatcher/#findComment-95389
The catch can also prevents your coola getting coated in oil. I recently got a FMIC and the old one had a black residue on the inlet side:( Which reduces efficiency of the coola. This was running only about 9psi boost. As adam says, on higher boost the problem is worse. A catch can will trap the residue (hopefully) before recirculating the gasses through the induction system. A breather will just allow the gasses to vent to atmo, which I believe is illegal (emissions), please correct me if I am wrong
https://www.sau.com.au/forums/topic/6307-oil-breathercatcher/#findComment-97172
They are illegal......
With or with out the little filter, if it vents to atmo. it's illegal.
Any ways, if you are getting oil in the I/C pipes from the rocker covers spilling oil and fit an Catch can, you would get a performance gain.
If you don't have much oil then the you would not notice anything.
I my self had oil in the I/C pipes and recently fitted an oil/air seperator, made a big difference (only running about 9psi)...
My 2 cent's worth.
Cheers
Rob
https://www.sau.com.au/forums/topic/6307-oil-breathercatcher/#findComment-97264
is a oil catchcan just a empty can/whatever witch the oil just feeds into,and just put a little nipple on it to fit one of those little filters cause i rekon u could make 1 for like 50bucks tops of out ally
is there anything special inside it?
if i make 1 for me post some pics ya rekon ppl would buy any?
https://www.sau.com.au/forums/topic/6307-oil-breathercatcher/#findComment-97720
Yes there is usually stuff inside it, they are not hard to make, just stuff it full of wire wool scourer, the course type made from stainless (sell from woolies 3 for a few bucks) are 'supposed' to be the best, although if its in an oil catch can, I wouldnt think any type of steel wool will rust? Anyone confirm this????
https://www.sau.com.au/forums/topic/6307-oil-breathercatcher/#findComment-97766
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
