heya all.
getting my new clutch on wensday its a just a ordinary heavy duty,
fitted and installed for $630 (inclluding alligning the flywheel or watever)
wat im concerned about is will the heavy duty be fine?
atm my r32 is pretty much stock, but in the future im planning to give it a bit of work, hoping to bring it to about 200 or so rwkw. is this clutch fine,
like would it do the job?
or would it be better of to just get brass button, (but atm..cant afford it)
https://www.sau.com.au/forums/topic/63101-new-clutch/
Do NOT get a brass button clutch. I don't understand why people think these are good for the street: it is not their intended purpose. If you try and drive it like a normal clutch (slip it) you will wear it out in no time at all.
Besides which you are hardly pushing the power envelope.
LW.
https://www.sau.com.au/forums/topic/63101-new-clutch/#findComment-1191093
