I have a whole load of r33 parts for sale. Here is just a quick list with some prices. If it's a bit too high, make me an offer, I may consider it. If its not on the list PM me I may have it. Cheers. Oh and if you want to just chat, MSN Messenger is the way to go... [email protected]
Cheers.
Front bar cover (plastic) - 300
Radiator - 300
Condenser - 350
Bonnet-300
Front Guards - 200
Front Guard Indicators - 30
Complete doors - 450
Door shell - 200
Door lock - 20
Door lock hinge - 20
Door outer handle- 30
rear bumper bar - 250
tail light - 150
boot lid -150 not with spoiler
boot lid spoiler - 200
boot lid rubber - 30
rear wiper full assembly - 150
gearbox- manual- turbo - 1000
starter motor- 150
Tail shaft- 200
rear driver shaft - 150
rear cross member - 200
rear suspension -120
airbox- 200
stock exhaust- 250
Air Flow Meter - 150
Please note: the parts are sold as secondhand and come with a 30 day warranty.
Also Available:
R32, R33, R34 GTS and GTR Parts. - Look for my threads of PM ME
Mitsubishi FTO Parts
Nissan Pulsar GTIR Parts
Toyota Supra/Soarer Parts
180sx, 300zx Parts
If there if ever a question, PM ME! I don't bite. :)
https://www.sau.com.au/forums/topic/63193-r33-parts/
Hi gdtno can i plz get a pic of the front bar and front guards to [email protected]
Are these parts for a series 1 r33 gts-t.What condition are they in structural wise.:rofl:
thanks.
ill send a pm as well.
These parts are all structurally fine but may need respray
https://www.sau.com.au/forums/topic/63193-r33-parts/#findComment-1195139
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
