Redline Performance Cruise For The Salvos – Biggest Event Of 2005 13/03/05
  • Replies 121
http://forum.hot4s.com.au/messageview.cfm?...013&STARTPAGE=1
For all the details on the cruise
dj, geno8r and i will be cruising together from newy if any other newy people want to meet up before let us know!
I hope i make it, im having a blinda sat night, i'll try my hardest to get up in the morning & down a few red bulls. No promises though.
how many peeps are meeting in S.O.P..
as it will be my first cruise with SAU ppl..
want to get to knew a few people face to face..
^_^
I know i am going, so you will see me there, when i spoke to Adam from Redline he said that their could be anywhere up to 400 cars meeting @ S.O.P.
hey maybe ppl willing to put up plates of cars going and model and brief description so we can intro ourselves wen we're there?? :P
my plates AMM.48Y white r33 carbon bonnet...
as i got no idea on anyone from SAU will like to meet some mebers dat are local... sorri for being so NUB
I would rather not advertise my plates, but i have a white R33 GTST S2 M-Spec with the SAU stiker on the windscreen (that now has a crack from a f&$ken rock that a truck threw up :P:P )
PS. I will have my 15 month old son with me, so listen for the screaming, HAHA :headspin:
Ill be there...
White R32... stock rims... GTR kit and cracked front bar (i bought it like that)
Ill prob be near Redline as im good mates with them all so come say hi!!!!!
Should be good
Ed
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
