  • Replies 184
I was actually being nice I hadn't spoke to Adrian at all and to be honest I don't give a f*ck as all I was doing was congratulating you on having the car ready and all I get back is crap like "P.S. burnouts are for pu55ys who can't get low e.t.'s"
but I'm the one with attitude :cheers::(:)
Guest two.06l
yeah im sorry if that you thought that was directed at you but...as i thought adrian was the only person who knew about the 405 i thought he must have told you, so the burnout comment was directed his way. Sorry again if offence was taken. Thanks for the congrats. see ya sat if you dont ring.....
This is fu(king awesome!
BTW cheaterererers, just got this from www.sportcompactgroup.com so there'll be no piking out like little pusseh's on the day! Got it?
In a perfect world it would be great to have an event as pre-entry only but in the busy lifestyle we all lead these days it isn't always possible. So for all of you that haven't had time to get your entry form in because you've been busy working on your vehicle etc you'll be able to enter on the day.
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
