  • Replies 184
Theo drove down from Brissy and now he's turnin around and goin home! Just spoke to him on the ph.
Bit of a shame, he popped the engine on monday testing at Willowbank, went flat out for 2 days to fix it, got there to Sydney, and it rains!
Woulda bin interesting, it made 770hp ATW.
2.6l, no gas.
It's a shame that is cancelled. The only positive for me is that the weekend is alot more relaxed, and my car will be finished for the 9th. It's good that they didn't wait until the morning to postpone it so alot of the interstate guys have some notice.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
