YEAH BUOYO! I'm baaaack! Back in turbo-world again!
Originally posted by DR GTR
SQuiiz your ride is the bomb too man.
Hey air well done. I love Mr2 Targa
They are baby ferraris.
Well yeah they sort of do. But yesterday we were crusin down Norton St in Leichardt and this yellow F355 being driven by grandpa is going the opposite way. Of course in Norton St cars can only go at 3km/hr and I looked at the Ferrari next to the MR2 and it looked nothing like the MR2 :D
But as long as there are no Ferrari's around, and people aren't too cluey... you can get away with it sometimes.... barely :)
Originally posted by RONIN
it will beat an R32 GTST (with filter, exhaust & BOV) in standard trim :D
p.s. that's a modded R32 vs stock MR2 :)
Indeed, I can vouch for that too, they are not just slightly but considerably quicker than a stock R32 GTS4, probably over a second quicker over the quarter.
  • 4 weeks later...
ooohhh!!!!! hmmmm ideas ideas. Wonder how much it is!! I know the TRD2000GT kit costs $5000
I SORTA looked into it once.......wrked out to something like $4000.00 NZD's for the kit + shipping to NZ from the states + fitting + painting.
In other words HEAPS!!
But yeah, it's nice alright!!
Cheers
KiwiMR2
Ronin mate, u gotta be loving this thread! :D mr2australia.com isn't it?? :D
thanks a bunch for the 91 vid mate, i agree, not as good as 92 but still hella fun to watch the GTR's romp it in!
u thinking of a blue respary?? That would look totally hot on ur car....with white powder coated rims..... :drooling:
u got a timeframe for this?? or just an idea at the mo?
KiwiMR2: yeh it's hella expensive and not within my budget :D
SS8_Gohan: hehehe yeh I could start up mr2australi.com but I really don't have the time or commitment let alone the web gesign skills to do it :D No problem about the vids mate. I will be powder coating my wheels white and getting a blue respray. I wanted Calsonic R34 GTR Blue but not sure now. I am still considering other colours but blue seems the go ATM. I want it done by next years jamboree ;)
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
