when driving, usually when i rev to about 4-5 grand + i hear like a pinging noise.
ive put in octane booster prob about on 2 seprate occasions and it dosnt really help. just slightly.
does anybody know the reason of this? and if its a problem?
cause ive been told, that if u hear pinging, and u still give it, u can blow ur motor, so u gotta back off. is dis true?
also if it is a fixible problem,do u know how much sumthing like this would cost to fix?
thx
https://www.sau.com.au/forums/topic/63451-pinging/
make sure you are running as high a ron as possible eg bp ultimate 98. what mods do you have are you still running stock boost. what car is it etc etc more details are probably required, make sure the engine is getting enough fuel etc etc
yea, 95% of the times i use 98 octane fuel, usually vortex, but only here and there i use premium unleaded from mobile (95 octane) only cause its all i can get.
i own a 93' r32 gtst, with minamal mods. 3" exahust and pod filter. also im running stock boost.
https://www.sau.com.au/forums/topic/63451-pinging/#findComment-1193695
    • Let large companies that are making money off selling kits do the preliminary engineering for you. If they all do -10, then that is all you'll ever need.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
