Hey all,
A sad day for me. I don't really want to do this but my current finances and need for transportation have influenced this decision.
The car is an 85 R30 hatch with the L20ET engine. Recently dropped a cylinder, have pulled the head off and found it is most probably a broken ring (haven't removed sump)
The car currently has;
Wolf3D V3 ECU
Supra FMIC
Koni suspension front and rear
Speedy Hyperfang 15" Rims
Xtreme heavy duty clutch
K&N Pod filter
Bleed valve
VDO boost guage
Nardi Torino steering wheel
Trust gearknob
Sony CD player
JBL 6.5" speakers front and rear powered by soundstream amp
Other things that i may have forgotten....
Comes with full R30 service manuals (for the L24 but most applies to the L20ET)
Boxes of assorted spare parts
Will need new front left and right quarter panels and a new front bumper (still on the car but dented).
The rest of the car is in extremely good condition, the interior is excellent and the rest of the body is straight.
I am looking for $3500 for the car as is (including the engine/head. etc) or may consider keeping the wheels etc for a lower price. I need the money to pay off the rest of my loan so I can start again.
Car is located in Adelaide
Interested parties please contact me by PM here, MSN or email { [email protected] } or SMS 0414302551.
https://www.sau.com.au/forums/topic/63931-r30-skyline-rebuild-project/
Hey everyone price drop
New price is $3000 I cannot go much lower than that as I still owe over $3000 on my loan....
If I cant sell may just sell in pieces depending on interest
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
