Hey Guys,
Can anyone suggest any good places in Sydney where I could buy a helmet relatively cheaply? I was hoping for less than $200 (the cheaper, the better at the moment), although I don't know if it's possible to get them that cheap.
I want to take my car for another run at WSID in the next few weeks (and track days in future), but I don't have access to a helmet anymore...so it's about time i bought my own anyway.
Any help would be great - thanks.
https://www.sau.com.au/forums/topic/63998-helmets/
if you were going mountainering would you buy cheap rope ( "the cheaper the better")
think about it
Thanks for the analogy.
Whilst I understand the point you're making, your comparison of helmets to mountaineering ropes is slightly misleading.
All racing helmets in Australia are required to be certified by Standards Australia meaning that they adhere to particular quality and safety levels, regardless of price. You're generally not allowed to race without having a Standards Australia certified helmet, whereas I'm guessing you could use any bloody rope you want when mountaineering. From my buying experience, it would appear in most cases that the additional price is more associated with additional features and increased comfort level as opposed to greatly increased safety.
For the record, I ended up getting a full face helmet from Motorcycle Accessories Warehouse, Parramatta for $120.
https://www.sau.com.au/forums/topic/63998-helmets/#findComment-1220087
I ended up getting $80 open face from the same place. I tried the full face though and I thought it was a bit too full on. The dude at the counter daid I'll be crazy to get full face for car racing. So now I am a proud owner of THH mat black open face. Makes me look even more dorky than normal :)
Just think of 30+ Degree heat on the track with no aircon and full face helmet. Sweatilicious :wassup:
EDIT: Silly me, didnt realise this was in the drag section of the forum and you also said in your first post about doing WSID. My point is still valid for track though.
https://www.sau.com.au/forums/topic/63998-helmets/#findComment-1220127
ahh careful with the open face helmets. Some track day organisers (Motoconcepts for one) won't let you use them
Personally I would take it back and get a full face one, save yourself the possible disappointment on day.
they are farking hot tho! Try a couple of different brands to see what fits best, they are totally different shapes inside
https://www.sau.com.au/forums/topic/63998-helmets/#findComment-1221001
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
