Chilli EAT OFF! - Tues Feb 15th 2005
  • Replies 139
Also shall I print out everyones avatar on the colour printer in half masks so we can put them all on at the restaurant?
No seriously.......................................................................
I herby accept the invitation to the proposed meeting of The Honourable Councilors for the Borrough of Harrow and take this oppertunity to confirm my seat and also require one for my secretary.
I thank the honourable member Ska for ahring his Pink bits with us once again it is most pleasing to see that your skills with Pink bits continue to improve.
Holly fu
Cactus Jack's Rocks.
Being from Townsville, there is nothing much that can match this for Mexican food.
This place has the lot
Tuesday Chilli night
Wednesay Margaritaville
happy hour the lot.
Their Fajita's are the BEST!!!
I shall try and make it!
My record is only 2 bowls of chille.
ooh ooh.......I hereby decree that all constituants in possesion of the Oxide of Nitous, shall be obliged to give The Honorable Sir V8SkylineMAN a toke on said bottle.
    • R34DE as in R34 with an RB25DE? So did you get this? Or you planning to?  I'm not really sure what you're saying.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
