Just thought i'd post up a few picutres of my car now it has come back from the painters. I wasn't sure what it would turn out like but i'm happy with the result, a bit of a head turner... The pictures dont do the paint work justice!
https://www.sau.com.au/forums/topic/64024-pictures-of-new-paint-work/
Yup the colour is ford xr6 orange or blood orange. Nismogirl, it was the colour in my avatar, but it was a custom colour and i couldn't get anyone to match the colour when i wanted to fit a new body kit, so a full respray was in order, it used to be midnight purple with very very faint glitter and a pearl through it... Also the paint had faded around the shity stickers that where up the side, so if i ever took them off you could see the fading, wich would look crapy..
I got it done thru maroochy smash repairs, they did an excellent job... I cannot find any blemishes, scratches or anything wrong with the paint work at all. A great job indeed.. :P
*off topic* (hey josh/matt do any of you guys have kurt wimmers mobile number? I lost his number and need to get ahold of him, if ya's do could ya's pm it to me? cheers :) )
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
