  • Replies 52
Does look too bad at all.
You said it wasn't a perfect fit... Where does it fit not so right ? Any chance of a few close up pics ??
Then the decision.. Leave the gauge holder black and get a silver gauge, paint the gauge holder grey to match the A pillar and get a silver gauge, or leave the gauge holder black and get a black gauge...
Who's good with PhotoShop ?? :(:D
J
https://www.sau.com.au/forums/topic/64085-guages/#findComment-1203610
I have a boost gauge mounted on the A-pillar. It's in a pod I bought from Modyourcar.com for the R33. It's not a perfect fit but it looks O.K.
That web site is painful to use, I searched up and down, left and right, I can't find a single gauge pod for an R33 GTST. I can find a univeral one for ~$20, is that it?
Hi J , I vote for black POD and black gauge.:(
https://www.sau.com.au/forums/topic/64085-guages/#findComment-1203679
I've been quoted from etperformance (www.etperformance.com.au) that they're $37 for black or $49 for carbon fibre (look).
details
E.T. Performance Products Pty. Ltd.
6 Short Street
Dandenong
Vic. 3175
Australia
Ph. (61)-3-9794 9044
Fx. (61)-3-9706 8171
https://www.sau.com.au/forums/topic/64085-guages/#findComment-1203714
I have three defi guages in my centre console wheer the two centre vents were. I removed the vents and stuck the three 60mm guages there. I blocked off the vent behind withthe exception of four outlet holes which I routed via plastic pipe to blow air out between the guages into the main cabin of the car. I did this to help airflow when the air conditioning is in use. If any of the vents are closed or blocked air will be forced out the remaining open vents at a higher rate, so the side vents are doing an okay job for front passenger and myself. Also means the install is fairly clean, not advertising to general walker-bys that it's loaded with guages as well. I also have an Apexi RSM that is mounted just in front of my rear view mirror (G-sensor in the roof lining in the cavity around the roof/light controls), It sits up there, behind the sun strip quite nicely and again out of site to passer bys. Still very viewable from a driver perspective (you look at your rear view all the time), it's perfectly sized so that the front sun shades still go through their motion with out any touching or rubbing, also completely out of view of the rear view mirror, so there is no inconveneince there. See in the guage photos that the owner has a RSM, or SAFC, you could look to install it in the same location as me, so that way your warning lights at the bottom of the rev guage on the cluster are not covered up.
https://www.sau.com.au/forums/topic/64085-guages/#findComment-1204410
Is that three guage holder definitely for 2 1/16" guages???
Also you can get an Autometer A pillar single and Dual pod guage holder. As I am in the states I will source mine here, but have not seen a DIn sized one for three guages.
Modyour car has them here for those who cannot navigate the web...lol
http://www.modyourcar.com.au/?cPath=19_125
https://www.sau.com.au/forums/topic/64085-guages/#findComment-1204493
details
6 Short Street
Dandenong
Vic. 3175
Australia
They are also on ebay for less than that...
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...4526159816&rd=1
https://www.sau.com.au/forums/topic/64085-guages/#findComment-1212308
Actually now I think about it I might have bought the gauge and pod off Ebay. The pod is an autometer one for r33 skylines. I'd have to say I recommend them. Happymeal I reckon I'll get rid of the RSM anyway. Can't get it to cut the speed limit like I thought it would. Feckin thing perhaps I'm just not using it right. Who knows?
https://www.sau.com.au/forums/topic/64085-guages/#findComment-1213337
Well in truth, I have always been able to find the menu setting to cut the speed limiter, but only really had a car with one installed up to a speed where the limiter would have cut it, that was also when I had a different ECU in there (link computer), so I can't testify they always work, but I have not heard any other result of them not doing what they say. In the manual there are two ways of installing the RSM, with speed cut option or without speed cut option (just speed monitor), the speed cut option involves connecting two wires from the RSM loom onto the speed wire out of the ecu and 'snipping' the wire between the connections of the two from the RSM loom. Thereby stopping the signal circumventing the RSM. Maybe your wire is not 'snipped', obviously don;t go snipping a damned thing till you check pin outs lol :cheers: But that situation would stop the limiter feature in the RSM from actively cutting the speed limiliter effect.
https://www.sau.com.au/forums/topic/64085-guages/#findComment-1214004
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
