For a while I've had a the following turbo:
- CHRA GT30/40 (61/82mm "600HP" comp wheel and 60/55mm exhaust)
- Machined out 0.60A/R comp cover (don't know which type, as in T04E etc etc)
- 0.63A/R "Cosworth" internal gate turbine housing
I'd like help with identifying my comp cover (pic attached). Thanks in advance.
https://www.sau.com.au/forums/topic/64423-compressor-cover-id/
Its a T04B probably .60 ARR compressor cover . Way way too small for a GT40 compressor wheel . I'd like to see the "Cosworth .63 AR "Turbine housing . If its off the TA34 (wrongly called T3/T04E hybrid , a phrase coined by turbonetics) fitted std to the RS500 sierra , it can't work properly . The TA34 turbines had much less tip height than GT BB anything . If it was re-profiled (the turbine housing ) it is now junk . Why anyone would want to use these housings on a GT3040R CHRA is beyond me .
Firstly the GT3040R is not an ideal match .
Secondly the GARRETT integral gate exhaust housing kills the efficiency of the UHP GT30 turbine , leading to excessive turbine inlet or back pressure .
Thirdly the T04B compressor cover kills the efficiency and chokes to death the GT40 compressor .
You must remember that Area to Radius Ratios (ARR's) for turbine and compressor housings is worked out based on the original (native) wheels diameter . GT40 compressor wheels (82 or 88mm) generally use T04S comp covers which are huge compared to T04B's .
The individual who built that turbo has little idea or respect for how turbochargers work . Smaller GT30R's with the correct housings could make more power and have far better transient response than that thing .
Also note that the RS500 Sierras were a dog on the road and track , they had all or nothing power delivery and plenty of cheat components . For starters the turbine housings were extrude honed which enlarged the volute and ARR ratio . There were some illegal (larger) turbine housings as well . In a vain effort to chase RB26DETT power they were allowed external gates to control boost . No way the integral could bypass enough gass to allow 500hp from 2L (122 Cu in .) .
Do not attempt to emulate this turbo as a well set up GT30R is better all round .
The TA34's were the end of the road for bush bearing turbos , the GT's eat them .
Apart from that you think it's great..... :P Seriously, thanks for the input.
Photo of turbine end attached. I had the dodgy looking turbine back plate machined flush so that at least the turbine and wastegate flow was unrestricted.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
