If you dont mind buying on the internet, the cheapest place i have found is Perfect Run at about $385 including the control unit 2. Also xspeed have just the gauge for $218 +10% GST, there located in WA, but have an online catalogue.
https://www.sau.com.au/forums/topic/64500-defi/#findComment-1210035
u need the control unit 2 to do the light up display for the BF series gauges dont u ?
and u need it anyway if u wanna hook up two gauges? an elec one (oil temp say) and mech (boost) ?
All the BF gauges are electrical as far as i know, including the boost gauge. And you definately need the control unit 2 to run the gauges at all. The unit can run up to 6 off it i think?
https://www.sau.com.au/forums/topic/64500-defi/#findComment-1210623
Prices from Xspeed website:
Control Unit 2: $181.82
Boost: $218.18
Water Temp and oil temp: $172.73
Ex. Temp, oil press and fuel press: $290.91
But you must add 10% for GST. And i guess because they are already in the country there is not chance of having to pay duty?
I think perfect run are the cheapest for the control unit 2, at 9500 yen.
Im getting the boost gauge soon, if you end up getting the gauges i would be interested in finding out how hard installing them is and also if you get everything you need (sensors etc) in the kit.
Rhett
PS Dont tell anyone but xspeed also have copy Do luck type 2 kits for R32 for about $1200. Have to keep it quiet or else everyone will end up with them before i have had a chance to save up. ;-)
https://www.sau.com.au/forums/topic/64500-defi/#findComment-1210640
There is a new web based company opening up with some great pricing and service. Their sight isn't complete yet but I emailed them and bought an ARC intercooler for an EVO 2 at a top price. Their web which is under construction is www.runway7.com.au
You can email them at [email protected]
Hope this helps.
https://www.sau.com.au/forums/topic/64500-defi/#findComment-1212538
    • Wonder if JB Weld sponsored the event lol
    • There's a big difference between a car built with millions of dollars in R&D, and someone like yourself taking a normal sporty road car, and making it 5 times more powerful. At the same time, get a modern sports car, and you can turn them up towards the 1000hp mark a lot easier too. Also, give that Lambo another 20 odd runs, and chances are it too may break something.
    • There isn’t really a cheap upgrade here. If someone made a decent, bolt in 6 speed that holds some grunt, it would do very well. The 5 speeds suck. You can put a - OSG 5 speed gear set into it. Ratios are tall so it zaps the “zing” out of it. Had one, busted it. - PPG 5 speed gear set synchro or dog’s. Ratios are even taller. - An overpriced Getrag. Nice to drive, expensive to source now. - A sequential of some sort. Expensive, very expensive. How many times do you pop a 5 speed before you throw the toys out of the cot?
    • Yes, fair call. I don't have any special love for super/hyper cars but it was impressive to watch the Lambo line up against successive skylines without any problem at all.
    • Ok. What is the go to transmission upgrade that can handle some abuse with around 700nm at the hubs? Must be quiet gears as the car is being street used.
