hey guys,
got my 180sx for sale, its just in the spray booth atm gettin finnished of but when it comes out its goin to look realllllly nice...mwha!On 9psi the car made 256hp and on 13psi it keeps up with anntons 330hp 180. the car is pretty quick, scares me. recently compressiontested showen all cylinders in good condition readings from low 150s to high 140s. there is a slight rattle from engine mounts but for a buy like this all u have to do is fix the engine mounts. THe paint used was from house of colour (1 of the best paints) and was undercoated with a gtr blue and top coat with a gold qhich comes out green, through the sun u can see a tinge of gold and blue looks nice.im slightly neg so give me a ring on 0409479119 and we can talk more.
14GRAND WITH RWC AND 6MONTHS REGO. AND WITH REST OF PAINT.
Engine/Suspension-
sr20de N/A cams
Custom oil catch can
Td06-20g trust turbo
HKS 62mm external wastegate
Screamer pipe
Blitzz dd BOV
Pressure reless radiator cap
Custom tuned S/S manifold
Braided turbo lines
3.5inch zuarst all the way through
5inch cannon..nice and rumbles
Custom fmic neally the size of the hybrid ones
Custom intercooler piping made
Pod filter
Aftermarket coil overs of some sort
16inch rims sprayed white..looks nice!
camber top adjustables
Fuel-
1000cc injectors
Custom 3/4 inch fuel rail
massive fuel pump(will find out soon)
Looks-
hot green..as said
vertex rear bar
vertex side skirts
vented F/g guards
flared F/g guards
can suply b/n front bar
de-badged
rear spoiler removed
rear wiper removed
front wippers sprayed silver.
SUNROOF!!!!!!
computer-
Haletch computer
Haltech ignititor
Haltech boost controller
Haltech laurnch control
Haltech toque converter
Its got the cord ready for
the computer to be hooked up
interior-
all is in mint condion.!
Center console and other parts sprayed
in silver.
momo steering wheel
snap on seat covers
DEFI boost gauge
Defi control unit
Autometer 5inch tacho
speco oil temp
speco water temp
speco oil pressure
bottem 4 gauges arnt installed
stereo-
eclipse headunit worth 1g
after market front speakers
ECplise 4 channel amp
rear pionner 6x9s
phinox gold 12inch sub
custom ported 12inch sub box.
you can find pics here PICS
https://www.sau.com.au/forums/topic/64584-180sx-cheap-and-very-quick/
hey mate,
im antons mechanic, ive done most fo the work on his 180, since he came back from qld he's done nothing but rave about ur car, i near on had a to smack him one to top him from swapping you.
good luck with the sale, if you still have it in april, maybe ill swap my 33 with you. might see you then.
cheers
Linton
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
