i'm only talking of my experiences here, but ..
a. you dont need a fuel reg
You don't need a fuel regulator probably because you've got bigger injectors
He said he doesnt have the funds for them so he's going to need the FPR to bump up the fuel pressure to make 250rwKw.
Im also going down this route very soon with a 2535, standard injectors and HKS 256 EX cam
Probably would have been better with the inlet cam as well but hey, this is as far as I can go right now...
Not really interested in the injectors at the moment guys, I know you can get 240-250 out of the stock ones and i dont have a spare $700 to spend on something I dont really need.
So far it sound like i should go for:
 Z32 AFM, Fuel Reg & hi-flow tuned by Dave...
Is there anything that I have left out that I may need (excluding injectors :rofl:)
That’s the biggest understatement of the century... Theirs no point trying to up fuel pressure if your injectors can only flow stock amount.
No matter how much you change it via a FPR, It’s still only going to pump 380cc into the motor, and if you think you can get 240 - 250kw out of stock injectors go for it.
Because for the cost of $700 for an upgrade set, or for the cost of a re-build which you will be doing if you don't upgrade your injectors. I sure know which option I would go.
Theirs no cheap way when you get to that point. You can't expect to bolt on a bigger turbo, and not upgrade your fuel system. Because it just doesn't work like that.
You can increase the flow of the injectors by increasing the preasure, although I wouldn't go more than 10-15% more than stock preasure. This amount might just give you what your after without having to go to 550cc's.
lol bbq melted piston 6 :) (ages ago)
as long as people don’t do wat he did.. (run mass boost for to long) in a hot climate with almost stock everything cept avcr fmic n zorst
If you call 10psi Mass boost, when then I think you’re in trouble running 14psi. As that’s the biggest contradiction, Considering your running a stock Cooler, stock fuel system, stock computer, with a rb25turbo, (On a rb20) Running 14psi....... Ohh yer did I mention the Heat that your running it in !!!
Your setting a good example, just like your comment.
With a stock internal motor you can't expect to bolt on a bigger turbo, run more boost and keep the fuel system stock, it just not reliable. Bigger turbo = More Air, More Air, Needs more Fuel.
If you keep your injectors stock gunmetal 33, and you do the turbo upgrade.
I would like to see how long your car lasts until you are up for a re-build.
Hi guys, I need to clarify a few things here;
GCG ball bearing hi flow, no problems for 250 rwkw, best I have seen is 265 rwkw at 1.5 bar.
Upping the fuel pressure at the rail increases the fuel flow through the injector, but is isn't one for one. For a 10% increase in flow you need around a 25% increase in pressure. That's a lot more pressure (48 psi compared to 38 psi) so you need to make sure your fuel fittings, hoses, filter and clamps are capable.
Personally I would never aim for more than a 10% increase in flow, so 410 cc's is about the limit. Using the rule of thumb for a 6 cylinder, that's 410 bhp (306 kw) or ~ 240 rwkw. Best I have seen was 235 rwkw. That's using cleaned injectors with the highest flowing one in #6, the next in #5 etc. In a GTST this is due to #6 being at the rear, furthest from the radiator, not much air flow, radiated heat etc. Nothing to do with differential flow in the inlet system (like a GTR).
So you need to do the numbers, 1.5 bar = 22 psi + rail pressure 48 psi = 70 psi. Minimum you need a fuel pump that can supply 410 cc X 6 X 60 = 148 litres per hour at 70 psi. An R32 GTR fuel pump (used for the 265 rwkw) will do 190 litres per hour easily, as will a Z32, at that pressure. With reference to the attached tests on the Supra pump (make sure the part number actually agrees with yours) you can see that they are extremely voltage sensitive.......
At 12 volts they are below what I would consider a safe margin (155 litres per hour at 70 psi rail pressure). So if you haven't already done it, I would strongly suggest you run a dedicated supply to the pump from the battery via a relay. Use the standard wiring to switch the relay. That will get the voltage at the pump up to 13.8 volts (alternator output) and give you around 210 litres per hour, which should be more than enough.
OK on the Z32 AFM, although you might just get away with the standard R33 GTST AFM at ~240 rwkw. The Nismo "bolt on to the fuel rail" style of fuel pressure regulator will do the job for 70 psi ($149 from Nengun).
Bottom line GunMetalR33, the injectors will be the limiting factor in your plan, with around 240 rwkw being the most likely limit.
Hope that was of some help:cheers:
AAHHHGGMMM knowledge flexing....
Na just jokes, thanks for the great info. What happened to the attachment???
I personally would not bother with the highflow. go a jap brand, when it comes to it the price difference is not that much. I bought a gt-rs for $2800 from nengun, and sold my standard turbo for $450. which ends up costing me $2350 for my new turbo. GCG have them for like $2000 and its your standard one re-done so u save few humdred $$ for what? a highflow? i just personally dont think they are as good as a jap unit, but oppinions differ.
I'd agree that for the few extra $$$ it is worth going the Jap brand. in the case above $350 is very little!
So you guys just bolted the GTRS straight on, you didn't have to modify anything, buy anything extra or fabricate stuff? The GTRS fitted up exactly the same as the standard turbo? And it took you half a day to remove and replace, no special knowledge or tools required?
Then it made more power EVERYWHERE than when the engine was standard?
Then you took it out ot the drags in a full weight R34 GTT and it did an 11.9 at 120 mph?
There is more to a turbo than how much it costs on its own and the maximum power it makes at one RPM point. Personally, I take it all into consideration, look at what I expect from the car and then make a choice.
What sort of PSI are we talking to get the GCG hiFlow to produce the 240 mark you mentioned SK?
I have seen 240 rwkw at 1.2 bar, but remember boost is irrelevant, it is simply a measure of resistance to airflow. An example, the R34 GTT has cams and headwork. It makes 15 rwkw more at similar boost because the cams and headwork have removed the restriction, so it flows more air (to make more power) but the resistance (boost) is lower. I am sure the GCG ball bearing hi flow would make more than 1.5 bar if you stuck it on a restrictive/choked engine.
Guys, don't get me wrong, I am not picking on anybody or saying you have done it badly. There are more ways than one to skin this cat, I simply post up my way. That way readers can make their own choices.:)
PS; I don't place any importance in having a certain "name" brand product on my cars, I only care about how nice they drive and how fast they go. I can understand that some people want to have a "name" brand to impress people, but it's just not my thing.
lol bbq melted piston 6 :P (ages ago)
as long as people dont do wat he did.. (run mass boost for to long) in a hot climate with almost stock everything cept avcr fmic n zorst
You don't even know what boost he was running and how can you call,
Frontmount, full exhaust, pod all the usual stuff... STOCK ?
GunmetalR33,
I'd personally go bigger injector's for reliability, although you can push them to 250rwkw's as SK mentioned you have to change fuel lines and fittings etc to run that sort of pressure. You don't want a fire to break out in you'r engine bay!
I know what i'd do but its you'r decision , all i can say is you will notice the car will run, rev smoother with bigger injectors, same with bigger fuel pump.
Jun
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
