Ignition Timing
Guest N/A R33
This may seem like a pretty stupid question to some of you guys but here goes anyway.
How do you connect the timing light to the sparkplug on number 1 cylinder seeing that it's under the coilpack?
The way I think I would do it is take the coilpack out and plug in a normal coil and lead that way giving yourself a connecting point for the timing light.
Steve N:)
https://www.sau.com.au/forums/topic/6467-ignition-timing/
Originally posted by ylwgtr
NO!!!!!Under the module there is a wire loop that you can connect a normal clip on type timing light to.....it looks like a normal speaker type wire
hope this helps!
I have heard that loop is for factory diag i tryed putting a timing light on it and my timing was way out. i think by a few degrees as opposed to timing the actual cylinder..
Maybe someone can varify for sure because it would be good to clear this up, that loop is hell easy to attach timing light to :uh-huh:
https://www.sau.com.au/forums/topic/6467-ignition-timing/#findComment-97209
Yep - it is the wire loop at the back of the engine near the silver ignition-module-box-thingy - says so in the Service Manual for my car anyway.
A mate tried the same on his R33 & got the same results.
A very reliable source indicated that you will get maybe a couple of degrees difference in your readings from here when compared to measuring straight from the wire going to the coil itself - but who wants to stuff around taking covers off, etc.
Hope this helps...
https://www.sau.com.au/forums/topic/6467-ignition-timing/#findComment-97457
I have done all the work to my car but never ever done the timing on it.
So, you put the plug that was meant to go to cylinder #1 on the black loop wire on the ignition module.
Where does the other wire/s go?
dont get me wrong I am very mechanically minded but no one has ever shown me.
Doc
https://www.sau.com.au/forums/topic/6467-ignition-timing/#findComment-97469
Hope this helps...
But a couple of degrees out is not good enough
If this loop is the output from Igniter module straight to firing 1 cylinder then it should be 100% as long as your timing light picks up low level voltages or if it is a CT Current transformer type which picks up the firing pulses as a current...
But when i tried to time it from there all i got was about 8degrees TDC with max clockwise cam sensor turn
https://www.sau.com.au/forums/topic/6467-ignition-timing/#findComment-97595
ok....it will show up out because the car is not in service/dianostic mode........run it in service mode and you will get an accurate reading
you could be on to something there?
so use the loop and run in service mode, is there anywhere we can get instructions on how to use service mode?
https://www.sau.com.au/forums/topic/6467-ignition-timing/#findComment-99675
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
