Phews, thanks guys. Mine over heated once and its' cos' of the " sender " sit in the radiator screwed itself once, didn't trigger the thermal fan to work ( this was in a heavy traffic with dirty coolant and on a Melb HOT day, funny enough my old mechanic change my water pump and didn't give me new coolant not to consider a freaking flush ) so yeah. A new unit is on the way from Japan mean while i'm using one off YLWGTR ( Troy the man ).
As for the oil pressure gauge, mine always sit low but for peace of mind i had it tested out with a Mechanical gauge and it read alright.
The factory gauges suck. The water temp will sit on 1/2 until its too late. And dont even get me started about the oil pressure gauge :cheers:
I put a new oil pressure sender from Nissan in the car 20,000kms ago (2003) and its f*cked again already.
mine sits at half too...I know it's working cause it rose a couple of mm's the other day, I didn't want to take any chances so i immediately checked the engine and whadda know.. there was a leak in the radiator hose... I would've saved a heap right there, so what your reading sounds right but if it moves just a little then I'd worry
Mine never moves more than half a needle width, basically you can't see the guage moving.
Really really cold mornings/nights it will sit pretty much dead on half, its hard to tell exactly where it is sitting due to the guage which is decieving.
When the car is sitting in 40degree peak hour traffic where the AMB button reports 50degree's the needle sits 1/2 a needle width higher.
BUT it still doesn't go over ~90degree's, well it never triggers the engine overheat fan which apparently triggers at 90degree's.
The reason why the Skylines raise temp so fast (within 2km's) is the ecu retards ignition timing (can generally felt as a ever so slight flat spot on light throttle cruise and the turbo appears to spool a little quicker) + a few other little bits to get the car up to operating temp ASAP, this reduces emmisions and improves fuel economy.
Once you hit 100degree's the temp guage begins heading to 3/4.
If the needle begins to move around and you notice the engine overheat fan triggers check out the usual clutch fan and radiator blockages.
    • What's on the front of their building?
    • Jax Tyres Smithfeild Ive gone there a few time, well for tyres. on my 3rd visit I spoke to the dude and told how i just got slugged for rotors, brakes ect. His reply was golden; have you read whats on the front of the building. Never forgot it.       before picture, good friend got all these goodies installed.  Well time to study, servicing, maintenance all before this weekend driving lesson.
    • Hello, first of, I’ve looked at many threads on this code but none have helped me, if you know one that will help me feel free to post a link.   Now to my problem. Recently I was driving and noticed the check engine light came on. I went home and did the test to see what code it gave. I got the 21 code but everything seems fine with the car, no misfire, idle is good, acceleration is the same as when I bought it. I mean no signs of obvious failure. If no misfire is happening I can rule out the coil packs right? Which is about 98% of posts saying it is. If anyone has had this happen and found the issues let me know please. No other lights are on.   The car WAS due for an oil change. I since then changed it so idk if that triggers code 21. Either way it hasn’t turned off.
    • Your both right, it may hold a bit longer then.  Soon I need to change the synchros, should I fit the billet plate while I'm at it? Or just a waste of money?
    • Some of the east coast US Stagea got together this past weekend at Lime Rock Park in CT for Grid Life Circuit Legends. This is probably my favorite pic of the shoot with @Morgan.Mundahl on IG. Hope we get more stags out next year! i think I spotted 5 other than my own at the event.
