ummm.. i wonder whats gonna happen if u compair with same kw on both car??
and why compair HSV with NISSAN not with a NISMO??(e.g. NISMO 400R?)
anyway nice info u've provide... but i still like Skylines more than Holden... it just looks so much better...
cheers
  • Replies 350
k_hole
Registered User
Trader Rating: (0)
k-hole you sure you aint the reincarnation of skylinekiller or a buddy of sidewndr who have all joined on Feb 2005 just to have a look at how wrong all your comparison posts are.
and non of the holden or v8 supporters have answered my question about why do v8s need a 5.7L car with that much engine power to get a car to perform the same as a 2.6L car with 1/2 the power and its 10 years older.
The most enjoyable read ever was when they compared to R34 GTR to some New HSV in a speed mag i think. Both were equally modified (just a few small bolt-ons, boost and computer), and the T34 GTR beat the Holden in every aspect from rolling start to breaking etc... There is no argument that Holden has some catching up to do!
That was in Speed magazine I think yeah
The GT-R mauled the crap out of the GTS, and the GTS even broke some of it's drivetrain (I distinctly remember the 1 week old KAAZ LSD going snap)
But I'd have to say the most enjoyable read of the kind I've ever had was in Wheels magazine in 2002 I think, R34 GT-R V-Spec 2 Nur vs HSV V2 Coupe GTS
both dead stock
The Skyline pulled the Gen3 out the Monaro's arse
and I loved every word of it.
Maybe Skylinekiller should go read that article.
Thats easy, because GM can use light utility/truck engine as the basis of a performance engine to get cheap, reliable/durable performance. Throw in some alloy casting and the thing actually doesnt hurt sitting up the front of a sports car/sedan.
The V8 saves the hassle and complexity of turbocharges adding weight and heat, extra cooling / packaging requirements, adding to service intervals of the car etc etc.
And as for fuel economy etc etc. Think about it, if you put your boot into either, they both suck gas. Power is a result of flow thru the engine, and in turn the more power you make the more air you consume and accordingly the more fuel you need to use.
If you want to compare sports car to sports car, not sports sedan, compare the performance to a Corvette, an Ultima, a Robnell Cobra a TVR Cerbera. Lotus Espirit GT or another V8 powered Coupe/Sports car.:rofl: ...You start to realise that V8 powered sports cars are an expensive breed, even 2nd hand with the exception perhaps of a 928GTS
I cant believe this thread is still going...a think some Nissan drivers have blinkers just as big as Holden drivers:(
..and credit to Nissan the R32 GTR, they out foxed everyone in the old Grp A days. Holden were homolgating an ordinary sedan, Ford a shopping trolley, BMW a mass production rwd NA 4cylinder and Nissan go and BUILD a twin turbo, 4WD car from scratch to make the most of the rules and the class. They did the best job, but they did it with a blank canvas that was the R32 series, everyone else was throwing fibregalss and turbos/throttle bodies at road cars.
If you look at the job Nissan was doing with the DR30 and the R31 in the GrpA days, it just highlights the huge leap they took with the R32:thumbsup:
Thsi debate always ends in arguments, lol, i think thats why they are started, its as bad as talkign about who's girlfriend is better looking:)
all i'm saying is that this is a gimmick and its pretty funny
people like Roy have made some good posts so its not all a loss
why does nissan need 2.6L and mazda only need 1.3L then
just curious, ur arguing a point that makes u look even worse.
if you put a 1.3l next to a 2.6l and debate it all you like,
but then if i put the 1.3l mazda next to a 5l+ engine and compare the two it would make you look worse off, so you were better of not replying to anything
besides thats like comapring apples with oranges, pointless
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
