car bra for R34?
Guest neoGT-25
hey guys... my family is driving down to Melbourne next Saterday in my car... its black and i am shit scared about chips in the paint and so on... does anyone know where i can get a car bra for my car?
is there a better alternitive than a car bra?
anyhelp is apreciated as there are only 6 days untill i go...
please help :cool:
caio :burnout:
https://www.sau.com.au/forums/topic/6499-car-bra-for-r34/
  • 5 weeks later...
first of all...
why the hell would you want to put a car bra onto a 'line... omg.. ppl these days...
the reason you get a skyline is so that ppl see its a skyline.. and they give you respect..
car bras are ugly.. and bad..
Yeah, i think they're kinda gay... i've seen them on some pretty dodgy cars as well its like why bother. Personally with the possibility of stone chips you take the risk while driving anytime. Its going to happen driving along sooner or later whether on the highway or not. One day you might have to pay $500 to get the front bar resprayed, but its going take a while b4 it gets that bad.
There is always gaffer tape :D:)
https://www.sau.com.au/forums/topic/6499-car-bra-for-r34/#findComment-113734
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
