Post your best skyline shots.
This is a pic of Tokyo, alot of the quality was lost because i had to save to a smaller size so the dial-up users stand a chance.
http://members.optusnet.com.au/~jfinn5/mypic106.jpg
Wow... can we see a hi res version :cheers: Sorry, its aleady hi res, i mean hi quality, JPEG 60 - 80 will do it.
That is so nice looking! Akeenan if it was a bigger picture would be so nice!
yeah thats what i did.. i think im gonna have to get some version of photoshop back on my pc
In the meantime you could use IrfanView (http://www.irfanview.com/) or Picasa2 (http://www.picasa.com/) if you want a small download.
Would love to see a high quality version of that shot you posted...
LW.
ok i used IrfanView, one file saved at 100% and the other at 90%
http://www.members.optusnet.com.au/~jfinn5...n5/mypic107.jpg 100%
http://www.members.optusnet.com.au/~jfinn5...n5/mypic108.jpg 90%
both are still quiet large files, but the 90% pic loads fast on broadband.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
