why is that? did you work there?
Yeah worked up there doing shut downs for 3 years while i was doing my apprenticship.
Leave all the sh!tty work for the real workers to come and do it for the local guys cause they didn't want to break a nail :happy:
What you do there???
There is still plenty of ppl like that there :happy:
I Started 18 years ago as a T/A then went onto shift work in the machine room and thats where I still am.
Its goin good but im board of the power it makes! I really wanted sam to have a play with the tune and add more boost as it runs 16psi and tuned really safe & rich but i need better fuel. Its tuned for 95oct so maby the 98oct will help. So how much power do you rekon your car is gonna make once sam tunes it?
Edited by al_r33
Thats the problem, Once you do a mod, you think yea I like the power, but you soon get used to it.
I havn't got a clue what she end up with, :) I'm not getting my hopes up too high.
Just found out, its going on the rollers on Monday.
Edited by woolls
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
