Australian Grand Prix, Free practice session 1 results
1. ALONSO Mclaren 1m29.214s
2. MASSA Ferrari 1m30.707s
3. VETTEL BMW 1m30.857s
4. HAMILTON McLaren 1m30.878s
5. BUTTON Honda 1m31.162s
6. NAKAJIMA Williams 1m31.401s
7. COULTHARD Red Bull 1m31.528s
8. KOVALAINEN Renault 1m31.571s
9. WEBBER Red Bull 1m31.661s
10. BARRICHELLO Honda 1m31.737s
11. SATO Super Aguri 1m31.782s
12. FISICHELLA Renault 1m32.011s
13. WURZ Williams 1m32.194s
14. SUTIL Spyker 1m34.043s
15. LIUZZI Toro Rosso 1m34.627s
16. ALBERS Spyker 1m35.055s
17. HEIDFELD BMW 1m37.249s
18. DAVIDSON Super Aguri 1m39.221s
19. RAIKKONEN Ferrari 1m39.242s
20. R SCHUMACHER Toyota 1m39.550s
21. SPEED Toro Rosso 1m41.763s
22. TRULLI Toyota 1m44.130s
I WANT CROMPTON!!!!!!!!!!!!!!!!!!!!!!!!!!!!! >_<:happy:
Alonso just smashed the fastest time of the day. Hard to know which people are on hard or soft tyres but it looks ominous.
Another 41 hours and I will be at the track.
Yeah Billy just isn't the same hey!!!
The tyre rules are mad for this year >_<
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
