Want your car featured on the Newcastle Pro Sound web site header?
Hi, i'm currently designing the Newcastle Pro Sound web site. I want to feature some sort of import in the header. What im asking for is for a very nice photo of your ride, please no stock cars, something with a body kit or exterior aftermarket parts... Any shots of nice custom boots with fully sick subwoofers & amps hahaha but im serious that’s what I need. Mainly after a simple outside shot of your car which i can cut out to put in the header. Sorry there is no payment for your ride, just the fact you can tell people, "hey check out this url www.yadayada com, that’s my car in the header" I could easily use a pic of my car but that would be a bit of a pretentious thing to do seeing im designing the site.
I'll be finishing the design today so get your car photos in quick, If i see a photo I really which came in late 'eg tomorrow' i may quickly get to swap it over into the design, but this site preview will be sent off to the client fairly soon 'within next couple days'
Doesn’t matter what your ride is, either Skyline, Supra, Silvia, whatever, what works, works so please post'em up. If I don’t get any responses I’ll just use a shot of a m8’s s15 I think.
Cheers :)
I'll be doing a custom instal myself over the next few weeks....
All Phoenix Gold amp, speakers sub... and stinger cabling... will be takign shit loads of photos if you want a build up tutorial on everything from wiring, sound deadening n the boot job
send us a pm if u interested
Hey all. I just finished my online portfolio the other night which includes the homepage design I did for NPS so it you want to check out this thread http://www.skylinesaustralia.com/forums/sh...ead.php?t=65857 click the link to my portfolio & the current 'latest design' is a feature of NPS.
Cheers! :D
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
