hey people's just moving into a skyline but i thought i'd go hard and well lets say finance is nearly through on the GTR r34.
If anyone has ideas on how to avoid theft i'd like to know I realise no one lives in a crimeless area, so what can i do to protect the new baby?
Some have mentioned sensor light etc I'm interested to know does anyone park thier gtr somewhere other than home? Best alarms? etc
Open to ideas
Dazz
https://www.sau.com.au/forums/topic/65559-avoiding-theft/
QuickTrack or similiar is about the best protection, as well as an alarm that meets AUS and International specs. Mongoose make about the only range in which every alarm meets those specs (3 stage immobilisation, all black wiring, internal relays only, etc) I think. Vipers upper spec stuff does, but not their cheap gear.
https://www.sau.com.au/forums/topic/65559-avoiding-theft/#findComment-1224777
I saw this thing a guy got from jaycar. It was like a little remote sensor. You could put it anywhere. it came with a pager like thing which went off when motion was detected on the remote sensor. Kinda good if you can't see your GT-R because the sensor will notify you when there is movement that should't be there.
https://www.sau.com.au/forums/topic/65559-avoiding-theft/#findComment-1224890
Internal horn. Best ever!
I have heard of people jigging the lock and lieing in the car until you disabled the alarm, alot of people just look at the car, if there is no-one around, turn it off then look at it for a few minutes in case someone returns. Then they sit up and shimmy the lock and away with your car.
Internal horn stops that, if its hella fkn loud in the car, he aint gonna lie in it.
https://www.sau.com.au/forums/topic/65559-avoiding-theft/#findComment-1224938
I dont think I'd ever trust my cars wellbeing to something as simple as a single switch for the battery (not to mention the electronic parts that will shat having no constant power feed to maintain settings)....
3 stage immobilisation is much better, especially when coupled with QuickTrack or similiar in case they use a tilt tray. Internal siren is a good idea, but I've yet to see one that is loud enough to actually stop you fiddling in there. I've been in a car with apparently "THE LOUDEST LEGALLY AVAILABLE SIREN!!!" advertised on the packet... I was in there long enough to pinch it. I would have disconnected the siren too, cept the owner was next to me and I doubt he would have appreciated me doing that :)
Get an ultrasonic sensor if you want the coolness of a warning chirp when someone goes near the car. It has 2 fields, an interior and exterior field. If someone triggers the exterior field it chirps and alarm, but if they trigger the interior field the alarm goes off.
And get a pager too, so if you are out of hearing distance of the alarm you still get a notification.
https://www.sau.com.au/forums/topic/65559-avoiding-theft/#findComment-1226440
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
