1992 NISSAN SKYLINE GTR GUN GREY (PRE SEVS) rego till May 2005
approx 92.000KS ,Black Leather interior,Twin air pods, gauge pod,Apexi(boost)/Auto meter(air/fuel) gauges
genuine Greddy inter cooler , Blitz sbc boost control,New engine belts inc timing(recently installed) ,O/S Giken twin plate clutch,(recently installed)
T2 carbon fibre bonet,jASAMA 3"exhaust ,Sard R2D2 blow off valves,Bomex front bar,17 inch deep dish wheels.
Apart from the above listed the car is in standard form and has never been boosted ,the controller hasn't been put in but most probably
will be installed , but will not be running with boost before sale is made.
looking to get $36.500 will listen to reasonably legit offers no time wasters or test pilots.
Please take into consideration this car was bought into Australia over 4 years ago .well before the sevs law came in so you will be assured that the car isn't the rubbish that has coming into the country as of late. Also note that the sevs laws
have now changed and if you want to get in with a good one this particular car is a good example of a what a Grade 4 should look like! The car and is close to imac , It spends most its time locked in garages and close to never been driven.
Any expection or tests welcome but will not be taking people for "drives" unless they give some concrete show of interest in the purchase.I will say that
2 things need ironing out and that is it needs a wheel alignment (that probably will be done before any expection , compression test needed (also might be done before viewing) and rear wheels have yet to be polished
in chrome , something i never got around in doing . Apart from that its a regretful sale. The reason ?... well basically i need to get $$ to save for a roof and settle small debits still pending.
for more information or to make time for a viewing.
pm or please email
[email protected]
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
