hi guys,
its me again, I'm really confuse now where should i go? everyone is giving me different advice. Now, CRD and Rigoli are very good as well but CRD told me to get Power FC and Rigoli told me to get Microtech and both of them gave the same price which is $2200 ( ECU+Tune ) but one with PFC and the other one with Microtech( new virsion )
Jim ( CRD ) is a very nice guy except Lence.
Sam ( RIGOLI ) is a very nice guy too
Please anyone give me some advice, where should i go?
Thx a lot
https://www.sau.com.au/forums/topic/66109-crd-or-rigoli/
mate, both CRD and Rigoli are very reputable workshops. Both have prepared numerous top level cars over the years. both will charge you a premium price, becasue they have the runs on the board when it comes to performance tuning. picking which one just comes down to your personal opinion. Microtech has the advantage of dispensing with the need for MAF sensors (as it uses a MAP sensor to messure airflow), but won't be as nice a car unless it is tuned absolutely correctly. Power FC is a proven path for street GTR performance.
I would say that you shouldn't be dissapointed with either one of those workshops.
https://www.sau.com.au/forums/topic/66109-crd-or-rigoli/#findComment-1233327
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
