Does anyone have 19 inch wheels on their GTST R33?????
I am currently deciding weather or not to get 19 or 18 inch by 8 inch wide wheels and want to know if they will fit under the guards????
Also does anyone know if you can engineer(in NSW) 19 inch wheels on a GTST R33???
Any comments?????
Thanks
Brendan
https://www.sau.com.au/forums/topic/66118-19-inches-or-not/
SORRY DUDE I CANT help you out much, however i understand that most of the guys doing regular track work dont like to go bigger than 17s. anyway i have a gtst and am in the same boat as you tryn to decide what size, i reckon 18s
https://www.sau.com.au/forums/topic/66118-19-inches-or-not/#findComment-1236867
20's on a 33 gtst will not fit, you would have to modify the controll arms, etc.
I have 19's on mine, the tyes rub on the gaurd liners but not the gaurds. Be prepared to loose a little low end torque and some preformance, due to the bigger rolling diameter and heavier weight. On the up side, the gaurds are NICELY filled and the car looks lower than it actually is.
If i was to make a choice again, with my experiences with 19's, i would honestly go 18x8 at the front and 18x9 on the rears. Just less hassles and better performance.
PS: my wheels are 19x8 all round with f:245/35/19 and r:275/30/19
pps: the only reason track guys use 17's instead of 18's is purely a financial issue when buying rubber. I also have a track set of 17's wheel for the track :)
https://www.sau.com.au/forums/topic/66118-19-inches-or-not/#findComment-1237687
i had this choice when i was choosing diameter. I eventually went with 18 because of 1) price - tyres were expensive on 19's and 2) performance - i didnt want to comprise it for looks. My rims are f)18x8.5 r)18x9.5 - rears are filled perfectly. There is no hassle with camber/control arms scrubbing and if you want to make it look good than all that is needed is lowering.
https://www.sau.com.au/forums/topic/66118-19-inches-or-not/#findComment-1239487
pps: the only reason track guys use 17's instead of 18's is purely a financial issue when buying rubber.  I also have a track set of 17's wheel for the track :rant:
how the hell did u fit 275 on 8.5 ??
ive got 9.5 and have 265 on em...
Go for 17-18 if ur going for more grip while still looking good
go 19s for a show
https://www.sau.com.au/forums/topic/66118-19-inches-or-not/#findComment-1241081
    • R34DE as in R34 with an RB25DE? So did you get this? Or you planning to?  I'm not really sure what you're saying.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
