This great car would have to be one of the cleanest and cheapest R33 GTS25t Turbo's available in Australia at the moment. Original 2.5 Litre DOHC Intercooled Turbo Engine (Factory engine and has not been modified!!) New Timing Belt Fitted, New Brake Discs all-round.
Extras worth $$$$ included in the price are; 'GTS 025' Custom Plates, 3" Custom Mandrel Bent Exhaust with Turbo Dump-pipe, 'BLITZ' Full Auto Turbo Timer, 'ALPINE' Stereo (CVA1000E) Retractable Dash mounted Colour Monitor, 'ALPINE' Ai-net 6 CD Changer (located in boot & controlled by the monitor), Type-M Front Bar (front spoiler), Tinted Windows, Mongoose M80 Remote Alarm System with central locking.
The car is currently used as our family sedan and is a very reluctant sale. At this Price be quick.
Kilometres: 97,500 - Roadworthy with Car (Safety Certificate)
Year:1994, Auto Trans.
Pictures Here:
Front Picture
Exterior Picture
Engine Bay Picture
Interior Picture
STANDARD FEATURES:
4 Wheel Disc Brakes
Air Conditioning
Alarm
Feul Injection
Power Windows
Tinted Windows
Remote Central Locking
Power Steering
Electric Mirrors
Alloy Wheels
+more
https://www.sau.com.au/forums/topic/66190-r33-4-door-turbo-13800/
Thanks for the nice comments everyone, I've made an effort to be super reasonable on the price, especially considering some of the extras that I am prepared to let go with it ***cough*** Alpine Monitor ***cough***. Since I posted an advert for it on Carsales.com.au (just a couple of days ago) I've had plenty of positive feedback, so now I just need to wait for the right buyer. :)
Anyone else?
For 1 week only I will sell the car for $13,000 Flat thats an extra $800 off. If you contact me make sure to mention you saw this thread at Skylines Australia because this car is still up for sale at Carsales.com.au and carpoint.ninemsn.com.au for $13,800 (still the Cheapest 94 4 Door Turbo in Australia out of over 3,000 Skylines available on carpoint at the moment)
I would rather sell this car privately than to the yard's where they will only add their own cream to the price! I challenge anyone to find a better bargain on a 94' 4 Door Turbo. This car must be sold before my wife recieve's her beloved R34 coming from Japan.
See Contact details above. :D
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
