You can fit as many people in the car as you like (or rather can - 8 must've been cosy!!), as long as all the seat belts are being used. Came in as part of the national road rules. Same as being aloud to do a U-turn at traffic lights now...
I have a friend who is a cop and he told me this.
https://www.sau.com.au/forums/topic/6621-but-why/page/2/#findComment-99646
HIJACK.
So, has anyone else heard about this, any RTA verification?
https://www.sau.com.au/forums/topic/6621-but-why/page/2/#findComment-99811
Originally posted by HUSTLR
only 2 seat belts bro at da back
So what danny we all got dark tints at the small back windows no one woulda seen how many chics you had!!!!!!!!
This is one of thsoe things your gonna look back and regret :)
You shuda full known betta :lol:
https://www.sau.com.au/forums/topic/6621-but-why/page/2/#findComment-100183
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
