Just a quick reminder, this offer is ending on 30th of March which is very soon.
If payment is made before 30th, special price still apply.
If anyone is interested, please email me asap.
Thank you.
[email protected]
  • Replies 101
HASHIRIYA,
I forgot to thank you. I received the PFC about 2 weeks ago. It's in the car and working perfectly. I got a PFC + hand controller delivered to my door for under $1000.00 !!!!!! Yipeeee
Not sure whether any one out there has purchased anything from HASHIRIYA. I had absolutely no problems with his service. This is the 1st time that I've bought something over the net and NOT felt nervous at any stage. He kept me posted at every stage of the process which obviously kept me comfortable.
I paid for the PFC on a Monday and it was delivered to the door the following Monday.
Fasntastic. Many thanks once again.
