It's pretty painful to have to do this, but unfortunately due to current financial difficulty I think I have to. There is just not enough room in my wallet for two project cars in my life at the moment :)
That said, that I'm not desperate to sell unless I get what I'm after.
1985 HR31 Skyline Passage GT
* Munroe shocks rear
* White
* ACDthree (Nissan sports) mudflaps and boot spoiler
* 3" exhaust straight through
* RB20DET silvertop engine in good condition
* 5 speed manual (rb20 gearbox in EC).. clutch in GC.
* Speco boost gauge.
* Aircon works a tiny bit, will need new gas.
* Electric everything that even most of the newer models don't have - this includes seats, elec windows x 4, mirrors, cruise control, auto lights on dark, power steering, etc.
* S3 front bar
* S3 import rear
* IRS rear end with early HICAS setup
Rabbiting on starts here...
The good..
The car drives quite nicely, and pulls fairly hard for a close to stocker. The exhaust sounds awesome on it, and it really gives a killer RB note that will put a smile on your face.
These usually come standard with a rather tired and old "redtop" 2L engine. The engine, gearbox and ECU have been swapped out of an R32 and it looks like a professional conversion. The price of just the box and engine alone would set you back probably around $2000.
Heaps of room all around for daily commuting - and hey its still got 4 doors! Interior is blue.. nice and plush and IMHO nicer than some of the latter Passage trim.
Paint is still excellent. No big rust spots. Few minor pin dents that can be easily repaired.. or choose a colour and still have change from $10k.
Now the issues that I know about...
There is some problem with the handbrake assembly in the LHS hub. Probably an easy fix, but haven't had time to fiddle with it. If not I can probably point you in the right direction for a new one.
The front shocks are completely sponged. You're looking at about $500 for a nice pair of Koni adjustables for the front (The Shock Absorber Reconditioners will be able to sort you out there), or you can go a bit cheaper and get some KYB's.
Extras...
I'm also throwing in a 95% tread pair of 15" Sawa tyres (current rear tyres are bald)
Price..
$4600 ** SOLD ***
Basically I am selling this car "as is" for that price. It will probably need a few minor things for Roadworthy, and registration. But if you're willing to put a few hours in and do some running around, it's still a good price and a great project. For somewhere about $5.5k you can have it all running around nicely, which is several thousand dollars less than what a good Passage usually goes for, or anything with a silvertop RB20DET for that matter :)
Can probably organise transport to your state for around $300 or so, but you'd probably want to fly up and check it for yourself. A weekend trip to the goldcoast is a good as excuse as any.
This is a chance to own a nice japanese classic in good condition - you get as much looks driving this as a pimped up R33 or R32. Make a great daily driver, or do it up into something unique that is pretty damn orginal - there would probably be less than 50 (?) Passage's in QLD. Black tint, nice 17" rims and you've got a real attention grabber.
[email protected]
mobile: 0417 016 326
Here are a heap of shots...
hmmm sounds yummy...need pics asap....
would you be interested in a small daily drive with a few mods??? see my sig for mods (light) n the car is a series 3 nissan exa :P
no swaps... like I said, it's mainly for financial reasons so I need the cash. But if can't get a good price I'll just keep it and do it up myself, just will take a long time to get there.
just sell your existing car first ;) not many people take swaps.
Today just converted the front to the more modern Series3.. Just needs the proper import GTS grille for the proper import look at the front..
Price is only $4600 with the new front!.
Everybody who has been in this car is impressed by it.. something different and goes nearly as hard as an R32
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
