Hi guys,
Well I'm almost there, but I am currently S.T.U.C.K with an injector problem...
The Injectors will not fire and hence it wont start.
I have tested the injectors with a golbe and they are not getting any power/signal.
I am sure that it will run once they are firing but I can not work out why they wont fire.
The fuel rail has pressure, I have had the TPS out and it tested fine but has been rebuilt to make sure.
The throttle system seams to be working fine.
We have perfect spark.
just no fuel.
I have thought about trying a different ECU but surely given spark is ok it wont be the ecu? Perhaps its the Injector power supply? is there a fuse for the injectors?
Any ideas? very frustrated....
Cheers Stirlo!
https://www.sau.com.au/forums/topic/67153-injector-issue/
Cheers, but its not actually in any of the fuse box's, we have gone that avenue, we think that it may be the GTR's injector control system? as it may have failed or have a fuse in it. But we dont know where it is and or how, the 32GTR service manual does not specify (ie where is the power supply located and how does the control system work?)
https://www.sau.com.au/forums/topic/67153-injector-issue/#findComment-1247551
if you are checking the injector cycle with a a test light to the ametuer it looks like they are ****ed cause you would think they need a power pulse or a constant power to fire them but this isnt the case on a gtr. I cant remember its been a while but i think there is a constant earth and the computer provides a week power pulse, its been a while but i remember when i first checked a set i thought they were stuffed cause they didnt work how i expected them to.... best thing is to take the rail out leaving the injector sin and wired and turn it over and see if they are working or not!!!
https://www.sau.com.au/forums/topic/67153-injector-issue/#findComment-1247772
Yeah I dont have a spare ecu atm, but I have been told if spark is ok then the ecu will be ok. there are no error codes on the ecu, it comes up normal.
mate - must just be a loose wire there somewhere.... are you getting ANY noise/ action from the injectors??? I sould be able to lend you my ECU shortly (unless someone has one you can borrow now?) - unlikely, I know - but worth a shot.... Did all the power feed wires get reconnected back to the positive terminal of the battery?
you have fuel pressure at the rail - yes? could always pull an injector and try it on someone else's loom to see what it is doing (I think the injectors themselves are fine). I bet it is something simple...
https://www.sau.com.au/forums/topic/67153-injector-issue/#findComment-1250057
we re-addjusted the TPS and reset the ecu, checked voltages at teh ecu etc, but could not fault it.. however! apon doing a screw driver test, have now got the injectors firing and a strong fuel smell,... but we had lost spark???? fixed a fuse and have spark again and fuel...
BUT...
she will not start, it splutters and pops but will not run gets close at times, but just wont catch and run.....
Timing??? thats what it sounds like, Maybe the CAS? I guess the big Q is why?
I have reset the ecu over night and will give it a hit tonight to see if it just comes good.
but Yeah Daniel I would really appreciate a lend of one of your spare ecu's???
could just plug it in and see if it go's! - This would be nice, but judging by the list of problems I have had not likly!
https://www.sau.com.au/forums/topic/67153-injector-issue/#findComment-1251800
did you actually get an accurate compression test done on the car?? does it blow smoke when cranking?
the only way to adjust the base (idle) timing is via the CAS, so check this and make sure its in the right position for 20 degrees... even still i have heard/seen people advance and retard their CAS stupid amounts and the car still starts (has no down low power, but still runs) so i dont think its the CAS and/or timing, unless the timing belts not on correctly?
if you get hold of another factory ecu, run diagnostics on yours and it. if both show up ok, sounds more mechanical than electronic to me (and things like timing are electronically controlled on the rb26).
https://www.sau.com.au/forums/topic/67153-injector-issue/#findComment-1251840
    • About $4k brand new, available from vendors in Oz, or via an importer from Japan. Although that is for an R34 box, so you also need to buy the push clutch front plate (brand new from Nissan) and swap that over, and drill the bellhousing for a push clutch slave cylinder.
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
