Hi guys,
Well I'm almost there, but I am currently S.T.U.C.K with an injector problem...
The Injectors will not fire and hence it wont start.
I have tested the injectors with a golbe and they are not getting any power/signal.
I am sure that it will run once they are firing but I can not work out why they wont fire.
The fuel rail has pressure, I have had the TPS out and it tested fine but has been rebuilt to make sure.
The throttle system seams to be working fine.
We have perfect spark.
just no fuel.
I have thought about trying a different ECU but surely given spark is ok it wont be the ecu? Perhaps its the Injector power supply? is there a fuse for the injectors?
Any ideas? very frustrated....
Cheers Stirlo!
https://www.sau.com.au/forums/topic/67153-injector-issue/
Cheers, but its not actually in any of the fuse box's, we have gone that avenue, we think that it may be the GTR's injector control system? as it may have failed or have a fuse in it. But we dont know where it is and or how, the 32GTR service manual does not specify (ie where is the power supply located and how does the control system work?)
https://www.sau.com.au/forums/topic/67153-injector-issue/#findComment-1247551
if you are checking the injector cycle with a a test light to the ametuer it looks like they are ****ed cause you would think they need a power pulse or a constant power to fire them but this isnt the case on a gtr. I cant remember its been a while but i think there is a constant earth and the computer provides a week power pulse, its been a while but i remember when i first checked a set i thought they were stuffed cause they didnt work how i expected them to.... best thing is to take the rail out leaving the injector sin and wired and turn it over and see if they are working or not!!!
https://www.sau.com.au/forums/topic/67153-injector-issue/#findComment-1247772
Yeah I dont have a spare ecu atm, but I have been told if spark is ok then the ecu will be ok. there are no error codes on the ecu, it comes up normal.
mate - must just be a loose wire there somewhere.... are you getting ANY noise/ action from the injectors??? I sould be able to lend you my ECU shortly (unless someone has one you can borrow now?) - unlikely, I know - but worth a shot.... Did all the power feed wires get reconnected back to the positive terminal of the battery?
you have fuel pressure at the rail - yes? could always pull an injector and try it on someone else's loom to see what it is doing (I think the injectors themselves are fine). I bet it is something simple...
https://www.sau.com.au/forums/topic/67153-injector-issue/#findComment-1250057
we re-addjusted the TPS and reset the ecu, checked voltages at teh ecu etc, but could not fault it.. however! apon doing a screw driver test, have now got the injectors firing and a strong fuel smell,... but we had lost spark???? fixed a fuse and have spark again and fuel...
BUT...
she will not start, it splutters and pops but will not run gets close at times, but just wont catch and run.....
Timing??? thats what it sounds like, Maybe the CAS? I guess the big Q is why?
I have reset the ecu over night and will give it a hit tonight to see if it just comes good.
but Yeah Daniel I would really appreciate a lend of one of your spare ecu's???
could just plug it in and see if it go's! - This would be nice, but judging by the list of problems I have had not likly!
https://www.sau.com.au/forums/topic/67153-injector-issue/#findComment-1251800
did you actually get an accurate compression test done on the car?? does it blow smoke when cranking?
the only way to adjust the base (idle) timing is via the CAS, so check this and make sure its in the right position for 20 degrees... even still i have heard/seen people advance and retard their CAS stupid amounts and the car still starts (has no down low power, but still runs) so i dont think its the CAS and/or timing, unless the timing belts not on correctly?
if you get hold of another factory ecu, run diagnostics on yours and it. if both show up ok, sounds more mechanical than electronic to me (and things like timing are electronically controlled on the rb26).
https://www.sau.com.au/forums/topic/67153-injector-issue/#findComment-1251840
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
