Yesterday I saw a WRX scoop on a R33 GTS25t. What is going on? Do people not know that WRX scoops belong on Subaru's, Lancers and Mirages. So I quickly dialed 000 for the ambulence to help me recover and the police to make an arrest.
Just in case you wondering, I'm still a little ill. I've been told by the paramedics that it can take weeks if not months to get over such a shock.
W out.
https://www.sau.com.au/forums/topic/67222-wrx-scoop-on-r33/
lancers and mirages with scoops!?!?!?
you obviously don't your cars either, it probably was a WRX with an aftermarket front bar.
If you didn't look close enough you'd have thought the Auto Project GC8 was a R34 GT-R. I also almost bought that car. (See attachment).
https://www.sau.com.au/forums/topic/67222-wrx-scoop-on-r33/#findComment-1248231
I was joking. i didn't call 000, that was a joke too.
I know my cars quite well. it was a stock R33. didn't even have an after market exhaust or after market wheels.
don't get me wrong, I don't mind the odd venting in the bonnet though think it to be a little ordinary when someone places a WRX scoop on the bonnet around 20cm from the windscreen. Firstly, the car most likely didn't have a top mount IC. Secondly, why would you want a Skyline to look like a WRX. I like WRX's but they are two totally different cars. I don't want Ferrari tail lights on my R33 (though I wouldn't mind the Ferrari in full).
lighten up evo.
https://www.sau.com.au/forums/topic/67222-wrx-scoop-on-r33/#findComment-1248562
Yeah its like a connon on a VL it just doesnt suit it, i know a VL has got the worlds best motor in it, made by the best motor company ever! But thats different VL's woth cannons is rice in my opinion anyway. And whats with those KIA things with the WRX scopp and the gold wheels, arethey WRX's wannabes or what!?
https://www.sau.com.au/forums/topic/67222-wrx-scoop-on-r33/#findComment-1248644
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
