rms is irrelevent.
Al is correct. You need to build a box with the specified volume from the manufacturer. It will sound like crap with the wrong size box. Not all 12" subs require the same volume.
If I may be so bold I might just pull you up on that comment champ.
When I design enclosures for subwoofers the T/S specs are not the only thing that I use in th PC. Power availability does have a huge impact on the design of the enclosure, as does the size of the car, the volume desired and the music styles listened too.
The most peculiar thing is that once the enclosure has been designed it often is no where near the recommended size. This is because many manufacturers often recommend the safest enclosure volume for minimal returns rather than the absolute best performing enclosure. :(
Just wanted to get that out. :P
https://www.sau.com.au/forums/topic/67291-size-for-box/#findComment-1259167
39 leters is about the average size these days for a seald box as most subs for cars are, a seald box will allways make a sub produce more power. but on the other hand a ported or somtimes larger box will give the sub a nicer tone or note but is not done very often in cars as when you drive most of what you hear will be DOF! DOF! DOF! most peple in there teens or mid 20s dont realy care to much for tone as they prefer max volume - "if its to loud, your to old!"
https://www.sau.com.au/forums/topic/67291-size-for-box/#findComment-1267972
hey just gonna pull you up on a few points there mate....
no, a sealed sub box will not produce more power. neither sub, nor enclosure will produce any power increase.
ported/bandpass enclosures don't necessarily give a sub a nicer tone. in "most" instances, ported enclosures are used to optimise the output at or between certain frequencies. this is why you'll find most serious spl competitors using vented boxes and, lets be frank, most spl cars sound like ass when it comes to linearity and natural reproduction. vented boxes don't sound "nicer" in most respects either. while there are many drivers that sound lovely in the right ported/vented alignment, sealed designs usually offer much higher transient response (tightness/punch/impact/whatever adjective you like to use).
on one other note there, you're right in that increasing a sealed enclosure's volume will decrease Q (improve the sound.. sometimes). having said that, you shouldn't take a driver that sounds crap in a 30l enclosure and put it in a 100l box and hope it sounds good...
/end rant :)
d
https://www.sau.com.au/forums/topic/67291-size-for-box/#findComment-1270007
  • 1 month later...
it is a known fact that a seld sab will always handel more power than a venteted one becouse the air in the box will pull the sub back faster than a ported so it dosent distort if you turn up the volume that little bit higher.
https://www.sau.com.au/forums/topic/67291-size-for-box/#findComment-1339736
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
