hey - what you need to do (if you want to do it the easy way) is get some paint stripper, wipe it on with a rag on the painted sections (follow directions). this will get rid of the paint. you can then redo, or sand any areas that require more attention.
To polish, go to your local hardware store and usually in the power tools section you will find a Buffing/ Polishing compound KIT. it contains a grey and white block of the cutting/ polishing compound and a buffing wheel that attached to your drill. LOTS easier than doing it by hand :) BTW - the kit is only ~ $30. it shines it up like chrome!!!
or send it off to Mark the Polishing Guy :(:D
For someone that just wants to give it a go its way to much hard work to get right....
and if i was polishing something, i would be looking at more like 1200 grit sand paper or more if they make it.... the higher the number, the smoother the finish
Cheers guys! I have already looked in a couple of hardware stores and 1200 is the finest they have. It just felt too rough. Obviously not.
2GU UP 2 : Not everyone has the cash to do that, but why pay for someone to do it when you can do it yourself. Alot more stisfaction doing it yourself too.
I'm pretty sure Boostn247 meant 1200 grit, not 120
agreed - I enjoyed doing a bit of polishing in my engine bay :(
chroming looks better than polishing
the engine bays were a WRX and a S15 that was like every nut botl and washer in the whole car as well so it wouldnt cost that much just for bits of the engine bay
I like chrome as well, but for $30 tops, I was able to have a bit of fun and get a mirror finish :(
yeh i agree, i did my plenum by hand, probs shouldnt have started it, but once started, it had to be finished. its not perfect, but i like it how it is.
not a fan of paying ppl to do up stuff for you, unless its specialist stuff. doing things yourself makes the car that much more apart of you.
cheers
Linton
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
