  • Replies 117
any news on an ETA?, or have you got them/sent them out yet?
cheers
Tom
Hi mate, sorry about the delay. Your item will be sent out on Monday by express post. You should get it Tuesday.
Please let me know when it arrives.
Cheers,
Greg Kruse - GK Technologies
www.gktech.com.au
received today ;)
cheers mate
Tom
Great to hear mate.
When the feedback system is working again please leave feedback.
Still a few of each color available!!
cheers,
www.gktech.com.au
Hi mate, black chromes are SOLD OUT!!!
Here is a picture of the chrome installed in an S13:
cheers,
www.gktech.com.au
Chrome and matt (grey) are still in stock. Black chromes are going to be ordered again tomorrow and will take around 3 weeks to arrive.
cheers,
www.gktech.com.au
Hey Greg,
Just wondering if you had any chrome ones in stock?
I know that the black ones will take a bit to arrive.
Cheers,
Nath
Hi mate, the chromes are in stock now :)
I leave for Hong Kong in 6 days (going for 2 weeks) so try and get orders in ASAP.
cheers,
www.gktech.com.au
  • 4 weeks later...
Hey Greg,
Was just wondering if you had any of these back in stock at all?
Thanks,
Nath
Hi Nath, I have the chrome and the matt in stock now.
The black chromes have been on back order for some time now :)
Greg
  • 4 weeks later...
g'day mate
still havent heard from you about the black chrome knobs
let me know if you can
thanks
Hi mate, doesn't look like there will be any more gearknobs coming in.
If I do get anymore in I will let you know.
Greg Kruse - GK technologies
www.gktech.com.au
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
