Due to the clash with Diggity's Birthday and waning interest, this event is cancelled.
*** CANCELLED ***
Sorry chaps, but it is just not gonna happen. Ah well, see you all at go-karting in May
actually it is likely we will be playing CS:S .... but we can crank up an older version if it suits you. Other games are of course welcome to be played if they take your fancy.
Hmmmmmmmm well i may have my new PC then anyway i shall see
If i do have it then would anyone been keen for some Desert Combat?
If i don't have it by then u think CS:S would run on a P4 2ghz, 512ram and 16MB Geforce 4?
I haven't got it installed, but I would be up for some DC (haven't played it for ages but enjoy the game).
I have an AGP 64Mb GeForce4 MX440 laying around here somewhere u can borrow or buy if u want. Your system parameters are ok, except for the video card. Although, I think it would run on the 16Mb card if you turn off all detail and play in 640x480.
cs 1.6 please. i personally havent played cs:s before but would image the graphics to be smick.
OH YES!
I dunno how but for some reason its alot more addictive that 1.6, i think its just cos of the GFX
And i'll pass Andrew on the 640x480 hahahahahahahaha
Anyone here seen DC2? or any of the previews available?
YUMMY!
But yeah i'd be down for some 1.6 and and also warcraft 3 if n e one is interested........
Last thing who has all the gear to set up the LAN?
I have a 16 port switch that I run fulltime in my home - and I have a wireless router too :rofl:
I have about 200m of raw Cat5 cable and a tool to crimp the ends, plus a heap of cables already made up.
welcome R33ing :cheers: - glad you can come.
Regardless of what anyone says - everyone is going to wear a name tag to this thing so that everyone can get to know one another.
Also for those that haven't been to my place before there is an 8-ball table and Ultimate Mortal Kombat 3 video machine in the rumpus room, and a 6 seater spa outside, so there will be plenty to do! Make sure you bring your bathers!
I have tracked down a Hyperdrive thanks to Dan D .... should make for more fun. We will be holding timed comps. on the night too! Anyone else got a Hyperdrive they can bring along in case we want to play 2 player?
  • 3 weeks later...
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
